hp Stream ( No 19v on power supplies )
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Hi got this hp laptop in for repair on inspection when u plug in the charger the white light next to charger port lights up thats it on inspection of the mother board i have no voltages on any power supplies i only have power at the first mosfet and i think its a diode next to it on one side i have attached a pic with the voltages .Any idea where to go next with this motherboard .
    Thanks Guys
    Your never to old to learn
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: hp Stream ( No 19v on power supplies )
    check the voltage PU6 pin 1 3 20 19 23 24
    Voltage PU5 pin 6
    • garrymc123
      • Apr 2010
      • 336
      • United Kingdom
      Thanks, techtiger but I'm kinda lost according to the schematic pu6 should be ISL6251A but on the board its a OZ8691LN and I can't find anything on it will I still take the measurements from the same pins. Thanks
      • on/off
        • Oct 2016
        • 333
        • Indonesia
        I believe your motherboard wasn't Quanta AX3/AX5, since no PCB marking or labeling for component on whole board. So definetely newer Quanta's motherboard, try search Code of mobo near RAM socket.
        • garrymc123
          • Apr 2010
          • 336
          • United Kingdom
          Cheers on/off i think i have found it TPT MV-0 20 E88441 this more like it
            • 21899
            No thats not it .
            • on/off
              • Oct 2016
              • 333
              • Indonesia
              Check this link:
              https://www.badcaps.net/forum/showpo...43&postcount=3
              • garrymc123
                • Apr 2010
                • 336
                • United Kingdom
                Hi guys Downloaded the boardview but i can't find pu6 on this boardview and also the boardview is different from the motherboard layout. Thanks
                  • 21899
                  Try to find the board id it will be similar to DA0Y0AMBC60
                  HP Stream 11-d: - Quanta Y0A
                  HP Stream 13-c: - Quanta Y0B
                  HP Stream 14-z: - Quanta Y08
                  • garrymc123
                    • Apr 2010
                    • 336
                    • United Kingdom
                    Found it
                    • on/off
                      • Oct 2016
                      • 333
                      • Indonesia
                      Sadly, seem the bv doesn't match. Use schematic just as reference.
                      Charging chips should be PU4 OZ8691ALN page30
                        • 21899
                        It could be this boardview http://sualaptop365.edu.vn/threads/b...bc-mb-c.19656/
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          You mean this one? http://sualaptop365.edu.vn/threads/b...0b-mb-b.19655/
                          • on/off
                            • Oct 2016
                            • 333
                            • Indonesia
                            Originally posted by piernov
                            Thanks, I think this the correct one. Also the BV seem match, only sub board give us confuse, because the layout BV was put together between mainboard with sub board, I think.
                            https://www.badcaps.net/forum/showthread.php?t=75275
                            • garrymc123
                              • Apr 2010
                              • 336
                              • United Kingdom
                              Cheers guys downloaded the files will i still check the same pins on OZ8691LN charging ic
                              • garrymc123
                                • Apr 2010
                                • 336
                                • United Kingdom
                                Right guys i can't find the datasheet for oz8691ln i was using the schematic but its a oz8691aln on it and it has 10 pins on the left side but on the schematic it has 9 so i don't know where pin 3 is but for the rest
                                pin 1 iout =19.73
                                pin 3 ?
                                pin 19/20 on same pad vbat = 0.352
                                pin 24/25 vsys on same pad = vsys = 19.72
                                • garrymc123
                                  • Apr 2010
                                  • 336
                                  • United Kingdom
                                  Also on vcc pin 9 on RT8172A CPU/GPU Core Power Supply i have no power but i do get charging light on power adapter connector
                                  • Techtiger
                                    • Oct 2014
                                    • 1602
                                    • france
                                    Pin 11 to 15 is your 19V in pins for the Chip, test pin 10 2 3 37 40 36
                                    • garrymc123
                                      • Apr 2010
                                      • 336
                                      • United Kingdom
                                      OK here are the voltages for those pins on oz8691ln
                                      10- pa = 5.804v
                                      2- acm = 0.380v
                                      3 - acp = 0.00v
                                      37 - addiv = 3.320v
                                      40 - vac = 2.583v
                                      36 - acav = 0.001v
                                      Thanks for the help much appreciated
                                      • garrymc123
                                        • Apr 2010
                                        • 336
                                        • United Kingdom
                                        Anyone ? are these voltages ok or can someone tell me what the abbreviations stand for ie (acp ) and i'll try and find out...Thanks
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • iMic
                                          Vintage AT Power Supplies - Selecting Capacitors
                                          by iMic
                                          Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                                          The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                                          02-19-2023, 06:45 PM
                                          09-06-2024, 05:59 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
