Asus ROG GL502VS - bricked BIOS
  • TheGiolly
    • Aug 2014
    • 8
    • Italy
    I bought an Asus ROG GL502VS (that was supposed to be) with bricked BIOS.
    I flashed the BIOS found in this post with a CH340G.
    Now I get light on the power button, caps lock and white power indicator but the screen stays off and the fans don't spin.
    I can feel that CPU and GPU get hot.
    I already tried resetting the CMOS using the 2 jumpers (SMD pads) near the RAM slots with no luck.
    Could somebody help me, please?
    Thanks in advance
  • TheGiolly
    • Aug 2014
    • 8
    • Italy
    Re: Asus ROG GL502VS - bricked BIOS
    I discovered that the Parade PS8330B chip gets very hot, too hot to the touch.
    Could it be the culprit?
    This is a Asus ROG GL502VSK, sorry for the mistake in the first post
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      Try with another bios first (check if on the bios there is the correct vbios version), if not work you have to start testing all the main voltages.
      have you tried if it displays with HDMI ?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        remove that parade chip and then try booting again. Is it hdmi controller??
        • TheGiolly
          • Aug 2014
          • 8
          • Italy
          First of all, thanks to both of you for your replies!
          I already tried multiple BIOS dumps from other website and the behavior is always the same.
          I have tried plugging a monitor in the HDMI port but I get nothing on the screen.
          I would really love to start checking the voltages but I don't have a schematic for this laptop. How can I do?
          That's a 1-to-1 DisplayPort 1.2 repeater. If it is the problem, will the PC boot without it?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Yeh, just gone through the parade datasheet .It says:
            "Supports DisplayPort and HDMITM/DVI dual-mode output"
            So, i do beleive PC will boot without it though not sure.
            • jasko_jacker
              • Oct 2014
              • 1140
              • italy
              Asus use only boardview and for some board is available a small part of repair guide, unfortunately for this model a boardview isn't avilable.
              • TheGiolly
                • Aug 2014
                • 8
                • Italy
                For now I think I'll wait to desolder it since I don't have a new one.
                I found boardview and repair guide for GL502VT. It's similar to my board but not quite the same. I can try to follow it..
                Do you think that a debug card with ELPC support would be helpful in my case?
                • Roham
                  • Jun 2019
                  • 9
                  • U.S.A
                  would you please share Board view and schematic of GL502vt with me too? and Bios file if you have it.
                  • jasko_jacker
                    • Oct 2014
                    • 1140
                    • italy
                    request it in bios section
                    • waakye
                      • Dec 2018
                      • 340
                      • Electronada
                      Hi TheGiolly,
                      DI'd you resolve the issue? I am having same symptoms with my ASUS ROG GL502VS
                      • waakye
                        • Dec 2018
                        • 340
                        • Electronada
                        TheGiolly, @Roham
                        Hi, I know it's been 5 years. Did anyone find a solution to this issue?
                        Thank you so much.
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • grimacelord
                          by grimacelord
                          07-10-2025, 02:52 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • throwaway327
                          by throwaway327
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          06-18-2025, 05:52 PM
                        • studdy05
                          Bricked HP Probook 450 G7 Bios questions
                          by studdy05
                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                          Ive got...
                          07-08-2025, 09:24 PM
