Lenovo g70-70 AILG1 NM-A331 no power
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3597
    • slovakia
    Hello have this Lenovo g70-70 AILG1 NM-A331 with no power. second p-mosfet have 20v on gate. i cannot find shematic. what to do?
  • lazaro.089
    • Jun 2014
    • 79
    • Mexico
    Re: Lenovo g70-70 AILG1 NM-A331 no power
    I found Lenovo g50-70 schematic maybe it does help as reference(?)
    • khaahk
      • Dec 2013
      • 776
      • Estonia
      NM-A271 could be somewhat similar.
      • piernov
        • Jan 2016
        • 4435
        • France
        First thing is to make sure both DC-in MOSFETs are not shorted.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3597
          • slovakia
          if thez was shorted, i will get 19V after them
          second is P channel so some charging logic is bad
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3597
            • slovakia
            i have ACDET, VCC, but no ACOK on BQ737
            replaced but still the same
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3597
              • slovakia
              i jumped second mosfet and voltages looks ok even after press power button. but no post and power just jump to 8W
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3597
                • slovakia
                MAYBE ite PROBLEM?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  BQ737-ACOK is supposed to be low.So nothing wrong there i beleive.
                  • piernov
                    • Jan 2016
                    • 4435
                    • France
                    If first DC-in MOSFET is fully shorted, both gates will have DC-in voltage on them, second MOSFET will never be turned on.
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3597
                      • slovakia
                      looks like u have right. first mosfet shorted between base and source. after replace power is good, but still no post
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3597
                        • slovakia
                        guys anyone can help with this?
                        after mosfet change, it self start. all voltages are good. cpu and gpu is heat, but no post. try to flash bios but no luck
                        • O.Szilard
                          • May 2019
                          • 161
                          • hungary
                          Hello. please help! Lenovo G70-80 NM-A331 does not turn on. 3.3V, 5V okay, bios okay. Charges the battery. When the power button is pressed, the power white LED flashes only once and does not turn on. has anyone encountered such an error?
                          • Sametbey
                            • Jan 2021
                            • 229
                            • Turkey
                            You can start by trying bios. Are the coil resistances and voltages normal, are there any heated parts.
                            I'm not happy to be so strong. because it's not humanly
                            • O.Szilard
                              • May 2019
                              • 161
                              • hungary
                              I experimented, heated a video chip, and started the machine, it works. Motherboard bga error
                              • EvilBzyk
                                • 10
                                • Poland
                                I add schematic.
                                https://www.badcaps.net/forum/showthread.php?t=79220
                                Last edited by SMDFlea; 07-20-2021, 04:11 AM. Reason: Schematic moved to schematic requests section
                                • PantherDave
                                  by PantherDave
                                  Hi all!
                                  05-29-2024, 02:01 PM
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                • Mita99
                                  Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                                  by Mita99
                                  Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                                  Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                                  Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                                  04-27-2025, 07:20 PM
                                • Dr.d
                                  Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                  by Dr.d
                                  I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                  Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                  04-05-2024, 11:48 AM
