Lenovo G710 doesn't work on AC power, only on battery (DUMB02 board)
  • FrozenHaxor
    • Jun 2015
    • 266
    • Poland
    I have an issue with this board, apparently it fell off the table on the charging port while still connected to the charger. Customer replaced the charge port with cable and whole connector, yet the board still won't charge the battery or work on adapter power. Laptop works fine on charged battery (with or without adapter connected). When Laptop is connected to the adapter and I take out the battery, it actually switches to the adapter power and continues to work for about 2 seconds then shuts off and stays dead until I insert a battery again.
    Adapter is not the issue there. It behaves the same way on my laboratory power supply. No current draw at all.
    Connector center pin shows 1V when connected to the adapter.
    3.3V and 5V coils are working when connected to adapter, there is power to the on button.
    BQ737 was replaced with known good part
    ACDET to this IC measures 2.8V, it has 19V power.
    Passives around it seem right, although I don't know their design values.
    Measured a bunch of mosfets, none of them seem to have shorts.
    Having no schematic for this board makes it difficult to troubleshoot. Did somebody come across a similar issue?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Lenovo G710 doesn't work on AC power, only on battery (DUMB02 board)
    You need to have the correct resistance to ground on the center pin, 550 ohms for a 90W AC adapter (assuming this is what this machines requires — confirm with what's written on the chassis). I'd try with another good AC adapter as using a lab power supply only confirms the DC-in power rail is not the issue but it cannot do anything about the center pin. (or you could wire your own resistor too…)
    • FrozenHaxor
      • Jun 2015
      • 266
      • Poland
      Tested with 3 good known original Lenovo adapters, one 65W and two 90W, and the Lab supply that always worked fine with every lenovo so far. The adapter for lab psu has 590 Ohm resistor in it. It powered countless lenovo laptops just fine before. Must be the mobo having an issue. Also confirmed that the charge port and cable is good, the resistance is sensed on the motherboard connector just fine when adapter is plugged in.
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        If the exact schematics file is not available, find the closest one among Lenovo schematics.
        • zhang
          • Jun 2017
          • 50
          • Indonesia
          "3.3V and 5V coils are working when connected to adapter, there is power to the on button."
          is it being tested with "adaptor only"?
          • FrozenHaxor
            • Jun 2015
            • 266
            • Poland
            Yes. This is adapter only. Everything seems to be fine but it just won't start up.
            • Techtiger
              • Oct 2014
              • 1602
              • france
              test the out put of BQ737
              pin 5 IOUT
              pin 7 ACOK
              pin 16 REGEN
              pin 8 & 9 SCL SDA
              • FrozenHaxor
                • Jun 2015
                • 266
                • Poland
                Test results:
                pin 5 IOUT - 0V
                pin 7 ACOK - 0V
                pin 16 REGEN - 6V
                pin 8 & 9 SCL SDA - 3.3V
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  Originally posted by FrozenHaxor
                  Test results:
                  pin 5 IOUT - 0V
                  pin 7 ACOK - 0V
                  pin 16 REGEN - 6V
                  For ACOK for this MB architecture may be Logic Low that’s why 0V , and for IOUT & EC no Communication 0V this why no charging, that pin is connected to a Cap test if’s leaking or short
                  • FrozenHaxor
                    • Jun 2015
                    • 266
                    • Poland
                    Pin 5 IOUT to ground is 100kOhm. Can't see any caps from that line.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Originally posted by techtiger
                      For ACOK for this MB architecture may be Logic Low that's why 0V , and for IOUT & EC no Communication 0V this why no charging, that pin is connected to a Cap test if's leaking or short
                      Yes, BQ737-acok is logic low.
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • Habble7
                        Lenovo ThinkVision P40w-20 no power – ILPI-422 VA board repair help
                        by Habble7
                        I'm trying to repair the power supply board from a Lenovo ThinkVision P40w-20 monitor. The board is labeled with the following markings:
                        - Main PCB code: ILPI-422 VA (dated 2021/11/24)
                        The monitor is completely dead, no power LED or backlight. Upon inspection, I found a few components that appear damaged, particularly some resistors that are burned and unreadable.
                        Attached is a high-resolution photo of the power supply board.
                        Does anyone have a schematic, boardview, or similar power supply that can help identify the...
                        05-15-2025, 02:38 AM
                      • pc_okay
                        LENOVO IdeaPad 3-15ALC6 - 82KU (board NM-D521) blinking continuously 0.5A
                        by pc_okay
                        Hello friends,
                        I have this laptop AMD Platform starting & not posting, fan spinning.
                        When i press power button, the board get almost immediatly 0.5A ~ and board get stuck at 0.5A with power button led blinking indefinitly.
                        If i stop the computer (pressing 5s power button), board stop and when i restart i get approx 0.37A ~ and
                        I try to reflash the bios with no luck, same result, and i try disabling onboard ram (i remove resistors accordling schematic), no more progress.
                        CPU and his area heat, maybe the cpu is dead?
                        10-21-2024, 10:23 AM
