ASUS N56VZ Black screen, wrong EDID ?
  • mikkele86
    • Apr 2017
    • 78
    • Danmark
    Hello.
    i have a ASUS N56VZ with black screen.
    Backlight is on and working. i can turn it on and off.
    intel HD 4000 working and driver up to date.
    I have tried all the classics, reinstall windows 1903 clean image.
    failsafe remove with DDU. etc. etc.
    the screen remains black.
    my screen is detected as "Flat Panel (1024x768 60Hz)".
    im suspecting it might be a EDID problem.
    I tried to read the EDID but im not sure if its done correctly.
    This is a first for me.
    The display is a "SAMSUNG LTN156HL01-101"
    Enyone who can help ?
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: ASUS N56VZ Black screen, wrong EDID ?
    First thing would be to try with another panel.
    The attached EDID doesn't seem like it's the EDID from the panel, but rather some kind of "default" EDID.
    • mikkele86
      • Apr 2017
      • 78
      • Danmark
      19v and 3.3v ok on both screen.
      Second display ok.
      Time for some diagnostics on the Samsung display ?
        • 20707
        What programmer did you use to read the EDID, and which chip was it. Was it the one marked 416WP
        • piernov
          • Jan 2016
          • 4435
          • France
          The EDID ROM is the one marked 402WP. I think the label on the board is "ICED", to the right of the LCD connector.
          Fuse F2 may or may not be the fuse that supplies power to the EDID ROM chip.
          • mikkele86
            • Apr 2017
            • 78
            • Danmark
            So i plugged in the Samsung display and its working again :S
            Could this just be connection gone bad ?
            i tried to push gently around the LCD connection and cable, all seems good
            • piernov
              • Jan 2016
              • 4435
              • France
              Yes, can be caused by a bad connection, that's why I said to try to clean the LCD connector.
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • Vincent Kahle
                Winbond 25Q16JWNIG – Asus ROG Strix Scar 18 G814JZ bricked after wrong flash – Need help
                by Vincent Kahle
                I hope someone can help me.
                I have an Asus ROG Strix Scar 18 (G814JZ) laptop with a Winbond 25Q16JWNIG chip on the motherboard.
                Unfortunately, I flashed the wrong file (BIOS/EC/other region – I'm honestly not sure anymore), and now the laptop is completely dead: no display, no fan spin, no reaction at all.
                I have a CH341A programmer and I'm able to read and write to the chip. However, I'm not sure which software is best (AsProgrammer, NeoProgrammer, etc.) or if there's anything specific I should watch out for.
                A valid BIOS/EC backup...
                06-05-2025, 09:27 PM
              • FallenOne008
                Asus G712L No Screen Backlight
                by FallenOne008
                Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                03-31-2025, 08:27 PM
              • krige
                asus g750js ms1130c (203) turns on nothing on the screen
                by krige
                hi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
                03-22-2024, 04:59 AM
              • Technodoc
                ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
                by Technodoc
                Asus laptop G614JZ-N3012W Rog Strix with i7
                Mainboard G634J-PMV-VGT
                6050A3441302-MB-A01
                2023-02-10
                Power button works okay....power light goes on
                Red "bottom" leds go on
                Charging led works
                Fans do not spin, capslock key does nothing, screen stays black
                I would like to program the bios again, to rule out a corrupted bios.
                However I run into a size error
                The bios chip is a Winbond 25R256JVEN
                Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                02-24-2025, 04:46 AM
