Acer E5-511 Motherboard LA-B211P heats processor as soon as I connect the charger
  • ruletero
    • Nov 2018
    • 182
    • Mexico
    Hi everyone
    I have this Mobo LA-B211P received from another technician.
    As soon I connect the charger the cpu becomes hot, also the 1.8v power supply.
    I suspect cpu is burned but I don't have enought experience and I want your opinion.
    I have 5v / 3v alw and the mobo try to turn on but not display.
    help please
    PD: sorry for my bad English
  • sourcebf
    • Jul 2016
    • 431
    • N/A
    Re: Acer E5-511 Motherboard LA-B211P heats processor as soon as I connect the charger
    yes I think it is the case....no chance with haswell cpu's and chipset
    • ruletero
      • Nov 2018
      • 182
      • Mexico
      mm ok nothing to do, I think it is that too.
      Very thanks
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Check PCH power coil for shorting. This i beleive has cpu +pch soldered in a single die. Cpu getting hot when powered is likely to be pch bad but you can never be sure. To be more sure, check resistance to gnd on bios pin8 and pch coil. In a dell cedar 13269 mobo, cpu was heating when adapter applied but at the end cpu was fine. it was only pch power ic which was shorted. So do check these steps .
        • ruletero
          • Nov 2018
          • 182
          • Mexico
          Hi
          Bios pin 8 to ground 4 ohms.
          This motherboard only have Cpu not PCH ( or is integrated, I don't know).
          Thank you
          • Luaina
            • Sep 2016
            • 12
            • Madagascar
            Yes. this fault is common in this computer. You can still replace it if you have the tools.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              So ,pin8 of bios chip is shorted to gnd for sure indicating a short in+3V line. The onboard cpu has pch integrated into it. So check PCH power coil for shorting now.
              • ruletero
                • Nov 2018
                • 182
                • Mexico
                I don't have the tools for replace the chip, so I prefer to no continue with the fixing.
                Thanks all!
                Raul
                • motormayhem
                  Lenovo T460 Only Charges on One Charger
                  by motormayhem
                  Laptop Question
                  I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                  A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                  05-12-2023, 01:46 PM
                  NVDC charger configuration...
                  11-05-2024, 03:28 PM
                • flat-earther
                  how to prevent a connected charger from draining battery when not charging?
                  by flat-earther
                  I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                  So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                  but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                  So the battery is backfeeding the charger and being drained.
                  How can I prevent...
                  08-07-2025, 01:04 PM
                • flat-earther
                  ASUS X54H laptop thinks it's always charging even with charger unplugged
                  by flat-earther
                  The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                  Windows also shows ''Plugged in'' when charger is not connected.
                  This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                  Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                  If I let battery run out and say it has 3% Windows will...
                  06-24-2025, 09:32 AM
                • Johndill
                  Dell Inspiron 7567 LA-D993P odd charger issue
                  by Johndill
                  Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                  There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                  I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                  Here are the tested scenarios:
                  1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                  2. With the laptop off, plug in charger (LED says on) & the front charging...
                  11-16-2022, 10:55 PM
