Gpu or vram failure?
  • myth77
    • Feb 2017
    • 380
    • Croatia
    I received this asus rog laptop with following lines/artifacts attached. Is this gpu failure or vram failure? Thx
    Oh, sorry for bad pictures...and ignore those two dots..its an old phone camera....my new phone is under warrenty repair.
  • zpi
    • Feb 2018
    • 132
    • Lithuania
    Re: Gpu or vram failure?
    You never know
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      I think gpu failure. try mild reflow with good quality flux
      • lorins_core
        BlackSmith
        • Dec 2012
        • 551
        • Philippines
        Can you try to Used External monitor to test? VGA Or DVI Or HDMI?
        • SluggerB
          Help with trying to fix phone that is not charging (Pics inside)
          by SluggerB
          I have two TCL A30 phones.
          Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
          New Phone: Works fine, bought as a donor board to try and repair Old Phone
          My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
          08-12-2024, 08:11 AM
        • keeney123
          new OS on a Sonim XP5s phone
          by keeney123
          To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
          I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
          05-13-2022, 07:19 PM
        • myth77
          Is this gpu or vram failure? Thx
          by myth77
          Ok, someone with expirience...what is this fault?
          03-06-2022, 12:16 PM
        • dreico33
          Asus Strix 1060 GTX NO VMEM Voltage & MATS Shows READ Error on Every VRAM.
          by dreico33
          Hellow guys,
          I have 5 Asus strix 1060 with the same problem. No Singal, MATS Shows in every VRAM Read Errors. and i dont have present VMEM Voltage.
          12V Present
          5V Present
          1.8V Present
          PEX Rail 1V
          GPU CORE Present 0,7v
          VMEM NO Volts
          PWM Controller
          VCC 5V
          EN 3.1 V
          VREF 2.1 V
          As far as i can understand or is a problem with the memory Controller ( in this case there is no solucion?) or for some reason the vram do not have Voltage. By the way i...
          09-02-2024, 10:31 AM
        • mikey5791
          Help with Samsung Galaxy J7 Prime phone
          by mikey5791
          Got this smart phone free from a guy who dropped it hard until the lcd display cracked with no seen display.
          Opened it and found the display ribbon cable partly damaged. I charged the phone full in 2 hours time, the led red light turns to green indicate full charge.
          Then i use a usb cable connect the phone to laptop but it only showed as media player with firmware version. Too bad there is no option to check folder.
          Does anyone know any method to check if the phone is working good? Looking forward for any advice and help possible.
          If tested the...
          09-15-2021, 07:54 PM
