Dell e5440 turns on but the screen remains black
  • poweron
    • May 2019
    • 371
    • italy
    hello, this Dell turns on but the screen remains black, if I press the power button a second time the fan turns at max and turns off, the voltages I measured in the pads are all, I tried to warm the cpu / gpu chip but nothing has changed, could it be a bios problem?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Dell e5440 turns on but the screen remains black
    Make sure RAM is good and compatible, and that you tried disconnecting any devices.
    If CPU VCore is present, try to flash the BIOS.
    Don't mess with the GPU or the CPU themselves randomly.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Screen remains black-Do you mean backlit ok and no data??
      • poweron
        • May 2019
        • 371
        • italy
        no, no data and nothing backlit, even on hdmi
        • poweron
          • May 2019
          • 371
          • italy
          yes, VCC_CORE is present 1.7v which of the two bios do you need to flash U1 or U2?
          • poweron
            • May 2019
            • 371
            • italy
            I flashed U2, the programmer ch341a told me file length, beyond range of will be ignored, I turned it back on, now the LED flashes 5sec on and 5 sec off and does not start, maybe the file is not right or I have to flash U1 too ?
            • flatline
              • Apr 2019
              • 23
              • united states
              Are you using those clip things to connect the ch341a to the bios chip while on motherboard? I have found that it doesn't always work 100%. I take off the chip and solder directly to ch341a pads, and yes, flashing U1 might work. But save your original .bin first of course. I have a e5440 board with dedicated graphics if you need those two .bins. I'm not sure what's wrong with it though. I know it's not the bios.
              • poweron
                • May 2019
                • 371
                • italy
                no, I don't use the clips, I hold the chip directly on the ch341a, I will try to flash U1 too then we see how it goes
                • poweron
                  • May 2019
                  • 371
                  • italy
                  I gladly inform you that after flashing U1 the screen turns on,although ch341a says file length etc etc, it probably doesn't affect
                  , thanks to everyone for the valuable advice,
                  regards
                  • poweron
                    • May 2019
                    • 371
                    • italy
                    everything works fine only when I turn it on the screen comes after 20 sec. I also downloaded a last 8 mega bios, downloaded from the dell site, but the problem remains, it can remain even so but if I can improve it is better
                      • 21929
                      Clean the ME management engine firmware: https://winraid.level1techs.com/t/gu...lization/31277
                      • poweron
                        • May 2019
                        • 371
                        • italy
                        I thank you, but how should I move to analyze and eventually clean my bios?
                          • 21929
                          You have a dual bios,you should flash U1 and U2 .If you can`t clean the ME yourself make a new post in the bios requests sub forum ,post both your original bios backups https://www.badcaps.net/forum/forumdisplay.php?f=40
                          EDIT: what is your service tag number .
                          • poweron
                            • May 2019
                            • 371
                            • italy
                            the service tag is: 13HGYZ1, bios version A04 can the bios be loaded from a usb key?
                            • HTR-Informatique
                              Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                              by HTR-Informatique
                              YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                              I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                              On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                              I also changed the screen because the PC fell and the screen was broken.
                              I changed the battery with a new and original battery.
                              I also had corrosion/oxidation on the...
                              02-09-2025, 06:51 AM
                            • smic717394
                              by smic717394
                              07-25-2024, 10:16 AM
                            • Swedishpower
                              Dell G3 15 3500 black screen
                              by Swedishpower
                              Hello
                              I have search everywhere for a solution for my problem, but cant find it anywhere.
                              When I was away to trow some garbage i always look in the electronic bin.
                              and this time i find a laptop.
                              Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                              the lamp for charmig is white.
                              Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                              but no Dell logo.
                              I tryed with a hdmi cable to another screen, still black.
                              I started to search solution and tryed...
                              07-06-2025, 06:18 AM
                            • andrhouseolly
                              Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                              by andrhouseolly
                              Hi.
                              I kindly ask you to help me solve the problem.
                              Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                              The board turns on, there is no image.
                              Read more. When the power supply is connected, the front panel indicators light up briefly.
                              When you press the power button, the button indicator lights up. The board works
                              there is no image, there is no matrix initialization, there is no image on HDMI.
                              When turned on, the fans do not spin, but when they warm up they start spinning.
                              When you turn off the button, the fans spin up to full speed for a short...
                              05-11-2024, 03:14 PM
                            • frannyjunk
                              Hisense 40H4F no backlight but turns off after splash screen
                              by frannyjunk
                              So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                              TIA.
                              09-24-2025, 10:59 AM
