Please help me identify a component
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: Please help me identify a component
    these mosfets do not concern the battery, if you want an help, please follow my instruction if you don't understand how to do it, ask for it.
    the goal is to understand if these mosfets work or is a problem with the charge ic. for a technician it's a piece of cake but I'm trying to make you understand why some tests are done. if you take measurements without knowing what you are doing, the situation becomes complicated
    • vtfe
      • Sep 2017
      • 35
      • france
      My bad. I totally understand what you are saying. I took the liberty to test the mosfets with the battery to provide extra info. Bad idea. From now on I will strictly follow your guidelines.
      Tomorrow, I will follow the procedure you mentioned in your previous post and post the results.
      Thanks again for your help.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        @jasko did you noticed he is saying multimeter beeps when testing chip number 3. I'm confused a bit by chip number 3. What is it? Does he mean resistor? If so then is not b+ shorted now??
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          @mcplslg123 you have right but @vtfe declared that with the battery the laptop post, so I think line b+ Is not in short.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            i think B+ was fine earlier. It got shorted when he accidentally touched the probe and smoke came. So now he needs to fix that B+ short first before we proceed further.
            • thesame
              DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
              by thesame
              Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
              The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
              02-27-2024, 04:31 AM
            • chth96
              How can I identify varistor which have been blew up?
              by chth96
              I mistakely pluged 100v japanese retro game console to 220v outlet.
              So It seems that glass fuse and varistor have been blew up.
              I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
              Is there any way to identify varistor type in my sega saturn PSU?
              Any reply would be appreciated.
              EDIT:
              It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
              11-26-2023, 08:52 AM
            • freakorio
              Need Help To Identify Component on Ymain LJ41-05120A
              by freakorio
              Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
              05-21-2024, 02:32 AM
            • baiceanu_stefan
              nm-f251 Schematic, boardview or help identify componente
              by baiceanu_stefan
              Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
              04-24-2024, 12:49 AM
            • cmn.fix
              FFN 551 IC need help to identify
              by cmn.fix
              Hi! I hope I am posting this in the right section. I need help to identify this component that is on an MSI Stealth GS77 with motherboard 17P11-07S around the graphics chip. Can't seem to find schematics or anything online about it. It looks like some sort of switch to me, I have attached pictures. Any help is greatly appreciated. Thank you! ...
              Yesterday, 08:09 AM
