HP G72 no DC jack led and no start
  • pecrie
    • Nov 2011
    • 182
    Hello ,
    I have been working on this MB - for some time now.Like I said , the led in the DC jack is not lit.
    There is no 3.3V on the Bios Rom (so the MB will not start).I do have the 3.3V on the EC SPI Bios chip.
    I have also noticed that on some (double) mosfets there is 19.xxVolt.
    But I am missing 1.x V -5.xV - 1.1V - 3.3V (bios) - 0.9V (for CPU)
    According to the schematic +V3.3A / +V5A should come from the EC IT8502E.But I'm not sure on what pins they should be.
    So any ideas ??
    I attach the schematic to this post
  • diif
    • Feb 2014
    • 6978
    • England
    Re: HP G72 no DC jack led and no start
    It's PU850 that creates the 3v and 5v not the IT8502E page 35.
    • Techtiger
      • Oct 2014
      • 1601
      • france
      Yep that’s correct PU850 check on the coil PL11 & PL801 for Voltage 3/5V, check pin 6 of PU850 voltage
      • pecrie
        • Nov 2011
        • 182
        Yes , but I cannot measure it on the MB.All the inductors (transformers) have 0 Volts.
        PU850 can create 3v and 5v but where are they going ?
        No voltage on the CPU -
        • pecrie
          • Nov 2011
          • 182
          On coil PL11 there is 3.3v.On coil PL801 is 0 Volt.
          Pin 6 of PU850 has 19.x Volt
          Pin 7 has 4.99 Volt
          So is the voltage on Pin 6 of PU850 too high ??
          • Techtiger
            • Oct 2014
            • 1601
            • france
            Check Pin 72 of SIO IT8502E for SMART_ID If your motherboard will not recognize the charger the DC check light will not light up
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3577
              • slovakia
              Pin 7 has 4.99 Volt
              If u dont know basic pins functions, than check IC datasheet.
              VIN is main power input and 19V is ok
              • Techtiger
                • Oct 2014
                • 1601
                • france
                Pin 7 has 4.99 Volt
                Pin 6 is power supply for that IC 19V ,for the PL801 put your multimeter in Diode mood and test for Ohms both sides of the Coil ( if you don’t know how to test Ohms check out YouTube)
                Near the PL11 coil there is a JUMPER PJ542 test that point for 3.3V
                • pecrie
                  • Nov 2011
                  • 182
                  @techtiger
                  Pin 72 of IT8502 has 0 Volt.And yes , I tested the PL801 in diode mode with respect to ground.
                  On both sides it beeps.
                  I will check the Jumper PJ542
                  @ktmmotocross ,
                  The schematic also shows for VIN - pin 6 - of PU850 3.3V.
                  Or I am interpreting this in a faulty way
                  Ok , I did check PJ542 there is 3.3V (I did mention this in one of my earlier posts)
                  I don't have 5.xV on coil PL801 and also not on the Jumper next to it.
                  So , no 5.xV then some leds will not lite up.
                  I did test the coils PL11 and PL 801 in diode mode - there is no short circuit to ground.
                  Something is preventing the 3.3V to go to the Bios Rom and the 5.x V is also not getting through.
                  I'm not sure if I will keep on working on this MB - it has taken me too long already.
                  But we will see
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3577
                    • slovakia
                    @techtiger
                    @ktmmotocross ,
                    But we will see
                    3.3V IN means it is input voltage for 3.3V highside mosfet. if u r not sure see IC datasheet, there are very usefull info, with description of every pin of IC.
                    beeping means nothing u must see value of that resistance to ground
                    did u check that charger id pin?
                    this board is not hard, but u must know what to look for. it is a good board to learn, because it is easy
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      As always on HP the AC adapter has to be recognized before anything. If you don't have the DC in LED lighting up, it will not turn on.
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • Wahaz
                        by Wahaz
                        10-30-2023, 08:42 PM
                      • Bloodhoundje
                        by Bloodhoundje
                        03-16-2024, 03:12 PM
