Alienware 18 LA-9332P 3V, 5V short
  • Johndill
    • Aug 2015
    • 314
    Hi, as far as I can tell, this board has a short on 3VALW and 5VALW and I am currently stuck on what to do next.
    PU100 gets hot when the AC adapter is connected so I assume it's shorted so I have removed it for testing.
    QZ1 is grounded on pins 1, 2, 3, 5, 6, 7, 8.
    PQ104 pin 5 grounds the DC jack shorting the AC adapter so I have removed it.
    PL102 is grounded on pin 1.
    PL101 is grounded on pin 1.
    PL501, PL502, PL503 and PL504 are grounded when the CPU is in, they are ungrounded when the CPU is removed.
    PL201 is grounded.
    QZ3 is grounded on pins 1, 2, 3, 5, 6, 7, 8.
    PQ201 is shorting the DC jack also and is removed for testing other stuff.
    As far as I can tell, 3VALW and 5VALW are shorted somehow and I have come to an end on where to go next so I;m acking the experts on what could be going on. Thanks :-)
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Alienware 18 LA-9332P 3V, 5V short
    It's not always safe to remove a buck controller and power on the board because then the gates of the high-side MOSFET are floating, and they could pass current, meaning sending 19V to the 3V or 5V rail. If you need to power on the board with the buck controller removed, either disconnect the PJP jumper, remove the output inductor or remove the high side MOSFET.
    Ignore PL501, PL502, PL503 and PL504, it's normal to have low resistance to ground there with CPU inside the socket.
    You have several places shorted to ground that should not be shorted together and are mostly unrelated. I'm not sure what happened but this doesn't look good.
    It's especially concerning to have PQ201 shorted but for now ignore that circuit as the 3V/5V circuit must be fixed first.
    You should try to isolate the shorts as much as possible, so remove QZ1 and QZ3 (which are probably dead anyway) and check which side is shorted for both.
    Disconnect PJP100, PJP101 and PJP102 and check which sides are shorted too. If they cannot be disconnected, remove PL101 and PL102.
    Also check for a short to ground on pin 3 and pin 13 of PU100.
    • Johndill
      • Aug 2015
      • 314
      I've replaced everything I removed except PL101 and PL102 as I removed them to isolate the short earlier.
      QZ1 removed:
      pins 1, 2, 3, 5, 6, 7, 8 shorted, pin 4 good.
      QZ3 removed:
      PL101 already removed:
      pin 1 short
      pin 2 good
      PL102 already removed:
      pin 1 short
      pin 2 short
      PU100:
      pin 3 good
      pin 13 good
      found pin 12 short
      cap PC117 short to ground, short was gone when I removed PU100 earlier.
      • Johndill
        • Aug 2015
        • 314
        Please refresh as I have corrected some mistakes ^^^
        • Johndill
          • Aug 2015
          • 314
          What should I try next?
          • Johndill
            • Aug 2015
            • 314
            Bump.
            • Johndill
              • Aug 2015
              • 314
              I'm not sure what else to test from here, suggestions?
              • Johndill
                • Aug 2015
                • 314
                Am I alone? It's so cold in here.
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3627
                  • slovakia
                  to be sure u mean short is resistance under 2ohms?
                  to locate short remove all components where u find shortted pins
                  • Johndill
                    • Aug 2015
                    • 314
                    Yes, short is under 2 ohms and continuity to ground.
                    That has been done in the previous posts but have still been unable to find the main short.
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3627
                      • slovakia
                      there are too many shorts. did u remove pu100 and check?
                      • khaahk
                        • Dec 2013
                        • 812
                        • Estonia
                        Use lab PSU to find shorts in +3VALW and +3VS, the same with +5VALW and +5VS rails. It is most likely not an easy job - probably need to replace many components (maybe too many). If successful then replace PU100 and PU200, measure mosfets - change if needed, check ram chip for short.
                        • Johndill
                          • Aug 2015
                          • 314
                          Yes, PU100 was removed in post#1, however the shorts remained.
                          I have been looking for a donor board for parts but from what both of you are saying, mine will be better off being the donor board instead, if I can find another AW 18 board to repair.
                          • Enderhelper
                            • Jun 2025
                            Had a 5V short on a similar LA board, had to remove around 12 components to get to normal readings on the rail (40k ohms after capacitive spike). Waiting on the chips from Ali rn just hoping the chips I ordered are all good, pretty much wishful thinking. It might be better to just use boards like for this parts.
                            • DynaxSC
                              Extreme High Current & Low Voltage Short Killer ??
                              by DynaxSC
                              Hi Folks
                              I'm looking for a extreme high current short killer solution for a reasonable cost.
                              I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                              After taking off the socket, the shorts dissappear again.
                              The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                              10-15-2024, 10:13 AM
                            • Stephen
                              MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                              by Stephen
                              I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                              02-06-2025, 12:03 PM
                            • adelfr2009
                              HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
                              by adelfr2009
                              I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
                              After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
                              09-28-2025, 10:21 PM
                            • Victor Moreira Silva
                              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                              by Victor Moreira Silva
                              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                              Well, my decice specs are the following:
                              Model: Acer Nitro 5 AN517-54-55T5
                              CPU: Intel Core i5-11400H
                              GPU: NVIDIA GeForce GTX 1650
                              Motherboard: GH51G LA-L181P Rev:1c
                              The symptom:
                              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                              05-26-2025, 10:49 AM
                            • aaronkatrini
                              Help me find the short circuit on this WORKING Nvidia GTX1650
                              by aaronkatrini
                              Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                              Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                              04-18-2024, 03:15 PM
