HP 820 G1 ,Blinking caps lock 3 times
  • kokono
    • Jun 2018
    • 203
    i have this board :
    SWBACK-6050A2560501-MB-A02
    it can start but only 3 times blinking .
    i reprogrammed Bios and EC but nothings
    attached original bios and new reprogrammed bios
    i know 3 times blinking ist Ram problem ,i changed with another model but dont change
    i measured ram voltage , i have 1.35V and 0.75V for ram
    any person have experiment? this problem ist hardware ?
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: HP 820 G1 ,Blinking caps lock 3 times
    it may be a CPU problem. Does it start Windows normally?
    • kokono
      • Jun 2018
      • 203
      it dont can start ,black screen,without bios screen
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3582
        • slovakia
        u have that board or whole computer that with that ram previously working?
        • kokono
          • Jun 2018
          • 203
          i have whole laptop, but i got it defect
          • piernov
            • Jan 2016
            • 4435
            • France
            Make sure you use known good compatible DDR3L RAM. Also try some contact cleaner in the slots.
            • kokono
              • Jun 2018
              • 203
              i testet with 8pcs DDR3L Ram and also tryed for contact cleaner
              any person have another good Bios?
              • kokono
                • Jun 2018
                • 203
                when press power button, wifi and speaker led lighting ,fan is off ,caps and num lock 3-times blinking and fan start with max rpm,
                in your opinion, ist EC problem or Bios ? or CPU?
                • caspian
                  • Oct 2015
                  • 1589
                  • Laptop
                  now, you should search the net to see what other people experienced with 3-time blinking on HP 820 G1. then, review their experiences here in this thread.
                  • kokono
                    • Jun 2018
                    • 203
                    my friend. i done
                    i searched before make new thread. most reason ist ram problem and i also see bios problem, all i done but for me not correct .
                    i maked a new thread,maybe Skilled person ,have good idea about Bios or Hardware problem
                    Thx
                      • 20782
                      Flashing a good bios or fixing your own with a clean ME usually fixes this problem. There`s a good good guide written by a Skilled person at win-raid https://winraid.level1techs.com/t/gu...lization/31277
                      Last edited by SMDFlea; 05-07-2023, 08:57 AM. Reason: bios removed, updated winraid links
                      • kokono
                        • Jun 2018
                        • 203
                        Thx for try
                        i reprorammed but ist same
                        maybe i have a cold soldering in cpu ?maybe connection between Ram and cpu have problem ? i dont know
                        • caspian
                          • Oct 2015
                          • 1589
                          • Laptop
                          Cold joints may happen under the CPU or on pins of the RAM slot. therefore, check pins of the RAM slot under microscope. The problem may also be due to a RAM that have dirty pads. The problem may also be due to a bent RAM slot that cannot hold RAM properly. Therefore, reinserting the RAM carefully may solve the problem.
                          • kokono
                            • Jun 2018
                            • 203
                            i checked complete Ram Slot under microscope
                            • peste
                              • Dec 2016
                              • 12729
                              • ROMANIA
                              try reflow cpu, but carefully ...
                              • Techtiger
                                • Oct 2014
                                • 1601
                                • france
                                test in RAM Slot Pin 75 30 1 126 199 203
                                • kokono
                                  • Jun 2018
                                  • 203
                                  pin 1 > 0.68v
                                  pin 30 > 128mv
                                  pin 75 > 1.35v
                                  and NOW complete dead, only power led light and after 2 second turn off
                                  i measuring EN in TPS51362 ,ist null .so it dont have voltage
                                  So at this time ,i dont have 1.35v
                                  maybe i have problem with KBC
                                  i have 1 volt for cpu but KBC dont send EN for TPS51362 (Ram power supply), its normal ?
                                  • caspian
                                    • Oct 2015
                                    • 1589
                                    • Laptop
                                    you probably have shorted some pins on the RAM slot. now, check what other voltage rails are present on coils.
                                    • caspian
                                      • Oct 2015
                                      • 1589
                                      • Laptop
                                      In addition, I guess the CPU had been defective before you made the short. Thus, do not worry about the short. Now, mainboard replacement seems to be a better option if it is cheap.
                                      • Techtiger
                                        • Oct 2014
                                        • 1601
                                        • france
                                        Originally posted by kokono
                                        pin 1 > 0.68v
                                        pin 30 > 128mv
                                        pin 75 > 1.35v
                                        pin 30 DRAMRST 0.128MV that's bad heat up the SOC CUP PCH side too much heat will cook the MOB
                                        • esqmooo
                                          HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                                          by esqmooo
                                          Hello everyone.
                                          This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                                          Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                                          Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                                          I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                                          03-11-2025, 03:57 PM
                                        • esqmooo
                                          HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
                                          by esqmooo
                                          I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
                                          03-07-2025, 05:55 AM
                                        • AdrenalinTL
                                          Caps and num lock blink 4 times
                                          by AdrenalinTL
                                          I am sitting with a very similar issue.
                                          Basically, had a probook that worked, gave it to someone, they returned it DOA. what the heck happened, I have no idea.
                                          Caps and num lock blink 4 times, as per HP, thats a board failure. I am very new to this, so perhaps I should be posting a new thread?
                                          Anyway, I resoldered the bios chip on after trying EVERYTHING else including reseating ram, cpu etc.
                                          Multimeter shows 19.5V on power, so I presume thats correct. Fan spins, no display. No post. Bios chip looks good from what I can tell just not sure how...
                                          04-09-2024, 10:34 AM
                                        • 08caine15
                                          HP 14s-cf0057TU caps lock blinking 3 long and 2 short
                                          by 08caine15
                                          Hi everyone , I need your help with this board and it's giving me a hard time . 3 long and 2 shorts base on HP site it's a MEMORY ERROR , tried replacing RAM it's still the same. RAM VOLTAGE has 1.2V i think it has a complete voltage a 3.3v and there's also ah 2v , tried checking pins if there any damage or unsoldered and everythings good , now I don't what should I do next. Also tried reflashing and programming the bios and still the same, hopefully there's someone who can help me with this since im having like 4 laptop with the same error.
                                          10-03-2024, 02:23 AM
                                        • ahmarzo
                                          Hp 15-cs laptop 5 times dc jack blinking white
                                          by ahmarzo
                                          I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
                                          First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
                                          Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
                                          But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
                                          12-28-2024, 04:46 AM
