Dell 15-7559 not charging, good battery
  • Bisketti
    • Oct 2013
    • 252
    • Ireland
    I have a Dell 15-7559 motherboard Daam9amb8d0 which does not charge the battery.
    1. Battery is confirmed good on 2nd identical laptop
    2. Dell Charger identified in bios as 130w (Original)
    3. Battery recognized in bios Battery is performing normally
    4. Bios was updated.
    Reading on battery connector
    9 -11 = 11.12v
    8 =3.3v Checked on scope signal good
    7 = 3.3v Checked on scope signal good
    6 = 0v with battery 3v without battery. so good
    Reading on PU15 charging IC
    1-4 = 19v
    5=3.3
    6=2.7
    7-10 = 0v
    11-3.3v
    12=3.3v
    13=1.3v
    14=1.19v
    15=.32
    16=1.05v
    17-20 = 11.1v
    21=1.02v
    22=0v
    23=0v
    24=6v
    25=10.8v
    26=11v
    27=11v
    28=18v
    Any ideas
  • Bisketti
    • Oct 2013
    • 252
    • Ireland
    Re: Dell 15-7559 not charging, good battery
    Schematics
    • piernov
      • Jan 2016
      • 4439
      • France
      Shorted DC in MOSFET
      • Bisketti
        • Oct 2013
        • 252
        • Ireland
        Hi u mean Pq32/37?, they seem to be reading ok but |I will change them and see
        • piernov
          • Jan 2016
          • 4439
          • France
          Pq40/pq41
          • Bisketti
            • Oct 2013
            • 252
            • Ireland
            Oh, what is your thinking behind that?
            • mielta
              • Apr 2015
              • 368
              Hi
              Works Laptop with Battery only ?
              • Bisketti
                • Oct 2013
                • 252
                • Ireland
                Originally posted by mielta
                Hi
                Hi no works fine with charger or battery just does not charge.
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  Same voltage on gate (connected to ACDRV) and source (connected to CMSRC) of PQ40
                  • alkaid
                    • Jul 2019
                    • 3
                    Hi Bisketti,
                    I think I have the same problem. Using power adaptor or battery works fine, but battery won't get charged. The battery is recognizable (detected and considered to be "charging") by both BIOS and the operating system, but the battery percentage never increases. I am also suspicious about the PQ40/PQ41.
                    What happens latter to your motherboard? How did you manage to fix it?
                    Thanks!
                    PS: I have zero knowledge about repairing motherboards. Just trying my best to find a possible way to fix my laptop (dell inspiron 5577). You have the same symptom and similar motherboard schematic.
                    • alkaid
                      • Jul 2019
                      • 3
                      Pq40/pq41
                      Hi piernov,
                      If PQ40 and PQ41 are the real issue like you analysed, any suggestion about how to repair/replace those two things?
                      I asked help from multiple local technicians but they think it is too risky to replace those them. Personally, I can't stand a laptop without battery
                      • Darkdes
                        • Sep 2021
                        • Scotland
                        Hello, I am having this same issue but I know the issue is the chip position labelled PQ32 literally has nothing there. Where can I source a replacement. Laptop is fell Inspiron 15 5577
                        • PradipKaka
                          • May 2022
                          • 4
                          • Nepal
                          I am facing the same problem receiving only 19v on 1-4 pn on batter done evrything replacing mosfet and resistor main charging ic not seems to working anythinng need help
                          • mon2
                            • Dec 2019
                            • 14672
                            receiving only 19v on 1-4 pn on battery
                            This is very high for the battery charge voltage.
                            Remove all power & with no battery. Meter in resistance mode (2k scale is ok).
                            Check each linked mosfet for possible damage as follows:
                            Source (1-2-3) & Drain (5-6-7-8)
                            Source (1-2-3) & Gate (4)
                            Gate (4) & Drain (5-6-7-8)
                            of mosfet @ PQ37; PQ32; PQ33.
                            Post each resistance check.
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • lawrenceptrini
                              Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
                              by lawrenceptrini
                              Hi Guys,
                              I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
                              The laptop is working fine with the adapter plugged in and also with a charged battery.
                              Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
                              ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
                              loses its charge, it stays on 0%.
                              Measurements taken
                              Charging IC (ISL95522HRZ) 32 pins
                              Voltage to ground with ac adapter only plugged in:
                              1)...
                              08-26-2024, 06:45 PM
                            • shatteredhalo
                              Dell Inspiron 15 5559 AAL15 LA-D071P battery not charging
                              by shatteredhalo
                              I'm troubleshooting an issue with a laptop where it doesn't seem to want to charge the battery. The laptop will run off the battery alone and use/drain the battery normally in this situation, it will run off the AC adapter alone, and it will run with both charger and battery connected, but it doesn't seem to charge the battery under any circumstance.
                              At startup of the laptop, the following error message is displayed by Dell SupportAssist: "Alert! The AC power adapter wattage and type cannot be determined. The battery may not charge. The system will adjust...
                              08-20-2020, 09:45 PM
                            • inkman
                              Dell battery not charging
                              by inkman
                              Dell battery.
                              7.4v
                              Genuine dell charger.
                              I have this dell battery thats been left on storage for long time
                              and its not charging anymore inside laptop.
                              Software aida 64 indicates battery has zero wear level,voltage at 2.8v.
                              I am using it in dell computer it came with.
                              When laptop is running, aida 64 indicates battery is not charging.
                              I think battery is locked.Please help me revive this battery, it is in really
                              nice condition.Any question please ask.
                              08-28-2023, 06:18 AM
                            • Julian Bailey
                              HP ProBook 445 G8 Battery not charging
                              by Julian Bailey
                              Hi all
                              We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                              The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                              I have gone around the board with a MM and cant find anything
                              Windows shows the battery fine,...
                              10-11-2024, 10:34 AM
