Dell Latitude E6430 doesn't recognize adapters
  • Andreasbest
    • Aug 2014
    • 1150
    • Hellas ( Greece )
    Hello!
    When i plugin the genuine Dell adapter it doesn't recognize it and therefore it doesn't charge the battery, it only keeps the laptop power on.
    (the charging battery led light up for 1 second and then goes off)
    In BIOS i get "unidentified adapter" message, tried other Dell adapters without luck though.
    These adapters work like a charm in other E6430 so it seems like i have a ptoblem in PSID circuit (page 44 in attachment schematic).
    Tried other Dell E6430 batteries too, no luck.
    I also tried other connector (pulled out from a working E6430 but with no luck, also the line seems intact with Ω meter.
    Uploaded some motherboard photos from the PSID circuit too.
    Any advices welcomed, thank you in advance!
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: Dell Latitude E6430 doesn't recognize adapters
    Dell use a Small chip stored inside charger that use a 1 wire protocol.
    Check the connection on power pin to motherboard, try to reprogramm ec firmware.
    • Andreasbest
      • Aug 2014
      • 1150
      • Hellas ( Greece )
      I checked the connection with another connector (pulled from a full working E6430) no luck.
      Also tested the connection between the plug and the motherboard with ohm meter.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        PR13 is 33 Ohms??
        • piernov
          • Jan 2016
          • 4435
          • France
          So you mean there's a good connection between the center pin of the connector and the pad on the board? Do you get 3.3V on the PSID pin of the connector?
          • Andreasbest
            • Aug 2014
            • 1150
            • Hellas ( Greece )
            PR13 is 33 Ohms??
            Hello and thank you for helping me.Yes the PR13 is 33Ohms.
            On the PSID pin i get 1.73V.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              psid should be 3v
              • Andreasbest
                • Aug 2014
                • 1150
                • Hellas ( Greece )
                psid should be 3v
                I know, this is why i'm here asking for your help
                • Andreasbest
                  • Aug 2014
                  • 1150
                  • Hellas ( Greece )
                  Can someone advice me in why 3.3v are missing?
                  • Andreasbest
                    • Aug 2014
                    • 1150
                    • Hellas ( Greece )
                    Can someone help me in why 3.3v are missing?
                    Thank you
                    • Techtiger
                      • Oct 2014
                      • 1601
                      • france
                      Voltage on PR12 PL4 PR13(both side)
                      • Andreasbest
                        • Aug 2014
                        • 1150
                        • Hellas ( Greece )
                        PL4 and PR13 have 1.73V on both sides
                        PR12 has 3.3v on one and 1.73 on the other side.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          PR12-both sides should be 3.3v
                          • Andreasbest
                            • Aug 2014
                            • 1150
                            • Hellas ( Greece )
                            • VogonJelc
                              • Nov 2018
                              • 7
                              • Montenegro
                              Did you check diode?pd7? Also pq2 did you check it? Resistance from gate to source?
                              • Andreasbest
                                • Aug 2014
                                • 1150
                                • Hellas ( Greece )
                                PQ2 gate has no contact with ground at all, therefore no resistance measure at all.
                                PD7 is missing from board (never soldered)
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  What about PU1 pin voltages??
                                  • Andreasbest
                                    • Aug 2014
                                    • 1150
                                    • Hellas ( Greece )
                                    pin 1: 1.73
                                    pin 2: 0 (grounded)
                                    pin 3: 0
                                    pin 4: 0.05V (?!)
                                    pin 5: 5v
                                    pin 6: 0 (grounded too)
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      I think you mean pin3 is 1.73V and pin1 is 0. Is that correct?? I doubt either pq2 or pq3 is bad.
                                      • Andreasbest
                                        • Aug 2014
                                        • 1150
                                        • Hellas ( Greece )
                                        yes that's correct, so where can we check after this?
