I see 19v in a few areas. None of the coils are shorted to ground. And I haven't detected any shorts in the obvious areas. There is no response when i press the power button. There is 0.00 Amps drawn from bench power supply at 19v power connector.
Dead no response. No lights at all. Got 3v at pwr button, But 0v at bios pin 1,8
Re: Dead no response. No lights at all. Got 3v at pwr button, But 0v at bios pin 1,8
Regarding PL20, PL21. When power is initially applied to 19v connector, they both get a quick blip of voltage for a split second, then down to 0v, almost too fast for the multimeter to show. I was able to read 2.1v at the aluminum capacitor c747 as it slowly discharges. Also, pin 8 on bios chip shows this quick blip of voltage as well.Comment
I checked (pu1) (bq24738H)
pin10 looks low, but I don't know if it's supposed to be 1v when board is at idle, then 3v when board is powered on?
pin1,2,3,20= 19.5v
pin4= 25v
pin5= 3v
pin6= 2.6v
pin8,9= 3.3v
pin10= 1v
pin11,12,13,18,19= 2.8v
pin14= ground
pin15= 0v
pin16,17= 6vAttached FilesComment
Okay, this one is interesting.
(pu10 APW8713QBI-TRG)
Pin1,2,3,4,5 = 0v
Pin6 =11.2v
Pin7 cycles from 0v to 300mv then repeats
Pin8 =19.5v
pin9 =19.5v
Pin10,11 =0v
Pin2,13,14,15 grnd
Pin16,17,18 =0v
Pin19 grnd
pin20 =0v
pin21 =0v
pin22 =19.5v
pin23 =300mvComment
This IC if fine it Enables after S3/S4 signelComment
Hi techtiger, PL16 is 150ohm with or without RAM.
PL21 3k ohm
PL20 70k ohm (takes a few seconds to settle fom 130K-70Kohm)
PU11 Pin1 7 8
0V 4.5V 19.5V
PU12 Pin1 7 8
0V 5V 19.5V
PL20,21 are 13ohm when I accidentally checked for ohms while power supply is still on board and supplying power. And of course, there is no voltage at PL20,21. But I guess that means there is a gate to ground?Comment
Pressing power button brings NBSWON1# from 3V to low state?
After that IT8987 should bring DNBSWON# high and give a short low pulse to cpu.
Cpu should respond with susb# and susc# going high.
IT8987 might need to be reprogrammed.Comment
Hello khaahk,
NBSWON1# press button, 3v then 1.8v blip, then back to 3v
DNBSWON# press button, 40mv for about 1second.
susb# press button, nothing happens, 0v
susc# press button, nothing happens, 0vComment
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by Loli PopuHello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Yesterday, 03:01 PM - Loading...
