Dead no response. No lights at all. Got 3v at pwr button, But 0v at bios pin 1,8
  • flatline
    • Apr 2019
    • 23
    • united states
    I see 19v in a few areas. None of the coils are shorted to ground. And I haven't detected any shorts in the obvious areas. There is no response when i press the power button. There is 0.00 Amps drawn from bench power supply at 19v power connector.
  • flatline
    • Apr 2019
    • 23
    • united states
    Re: Dead no response. No lights at all. Got 3v at pwr button, But 0v at bios pin 1,8
    Just want to add that I have a very basic understanding of these motherboards.
    • Techtiger
      • Oct 2014
      • 1601
      • france
      Check PL20 PL21 +5VS5 +3VS3 , PU11 pin 5 PU12 pin7 LDO 3/5 output Voltage & your RTC 3.3V section
      • flatline
        • Apr 2019
        • 23
        • united states
        PL20 and PL21 are both 0V
        PU11 pin5 is 3.3V
        PU12 pin7 is 5V
        • flatline
          • Apr 2019
          • 23
          • united states
          voltages at U9 for RTC
          pin2 is 0V
          pin10 is 3.0V
          pin14 is 2.8V
          pin15 is 3.27V
          • flatline
            • Apr 2019
            • 23
            • united states
            Regarding PL20, PL21. When power is initially applied to 19v connector, they both get a quick blip of voltage for a split second, then down to 0v, almost too fast for the multimeter to show. I was able to read 2.1v at the aluminum capacitor c747 as it slowly discharges. Also, pin 8 on bios chip shows this quick blip of voltage as well.
            • flatline
              • Apr 2019
              • 23
              • united states
              I checked (pu1) (bq24738H)
              pin10 looks low, but I don't know if it's supposed to be 1v when board is at idle, then 3v when board is powered on?
              pin1,2,3,20= 19.5v
              pin4= 25v
              pin5= 3v
              pin6= 2.6v
              pin8,9= 3.3v
              pin10= 1v
              pin11,12,13,18,19= 2.8v
              pin14= ground
              pin15= 0v
              pin16,17= 6v
              • flatline
                • Apr 2019
                • 23
                • united states
                Okay, this one is interesting.
                (pu10 APW8713QBI-TRG)
                Pin1,2,3,4,5 = 0v
                Pin6 =11.2v
                Pin7 cycles from 0v to 300mv then repeats
                Pin8 =19.5v
                pin9 =19.5v
                Pin10,11 =0v
                Pin2,13,14,15 grnd
                Pin16,17,18 =0v
                Pin19 grnd
                pin20 =0v
                pin21 =0v
                pin22 =19.5v
                pin23 =300mv
                • flatline
                  • Apr 2019
                  • 23
                  • united states
                  PL16 is showing 150ohm to ground
                  • flatline
                    • Apr 2019
                    • 23
                    • united states
                    pc182 seems to be open. It's a .1u cap
                    • Techtiger
                      • Oct 2014
                      • 1601
                      • france
                      PU11 pin 1 7 8 Voltage PL21 ohm ?
                      PU12 pin 1 5 8 Voltage PL20 ohm?
                      • Techtiger
                        • Oct 2014
                        • 1601
                        • france
                        Pin1,2,3,4,5 = 0v
                        Pin6 =11.2v
                        Pin8 =19.5v
                        pin9 =19.5v
                        Pin10,11 =0v
                        Pin2,13,14,15 grnd
                        Pin16,17,18 =0v
                        Pin19 grnd
                        pin20 =0v
                        pin21 =0v
                        pin22 =19.5v
                        pin23 =300mv
                        This IC if fine it Enables after S3/S4 signel
                        • Techtiger
                          • Oct 2014
                          • 1601
                          • france
                          150ohm with RAM or without ?
                          • flatline
                            • Apr 2019
                            • 23
                            • united states
                            Hi techtiger, PL16 is 150ohm with or without RAM.
                            PL21 3k ohm
                            PL20 70k ohm (takes a few seconds to settle fom 130K-70Kohm)
                            PU11 Pin1 7 8
                            0V 4.5V 19.5V
                            PU12 Pin1 7 8
                            0V 5V 19.5V
                            PL20,21 are 13ohm when I accidentally checked for ohms while power supply is still on board and supplying power. And of course, there is no voltage at PL20,21. But I guess that means there is a gate to ground?
                            • khaahk
                              • Dec 2013
                              • 760
                              • Estonia
                              Pressing power button brings NBSWON1# from 3V to low state?
                              After that IT8987 should bring DNBSWON# high and give a short low pulse to cpu.
                              Cpu should respond with susb# and susc# going high.
                              IT8987 might need to be reprogrammed.
                              • flatline
                                • Apr 2019
                                • 23
                                • united states
                                Hello khaahk,
                                NBSWON1# press button, 3v then 1.8v blip, then back to 3v
                                DNBSWON# press button, 40mv for about 1second.
                                susb# press button, nothing happens, 0v
                                susc# press button, nothing happens, 0v
                                • flatline
                                  • Apr 2019
                                  • 23
                                  • united states
                                  PU3 (NCP81101MNTXG)
                                  PIN8 Rising and Falling Voltage. What's BST?
                                  • flatline
                                    • Apr 2019
                                    • 23
                                    • united states
                                    PL14 is 110 ohms to ground.
                                    • Techtiger
                                      • Oct 2014
                                      • 1601
                                      • france
                                      Now check PU11 SIO pin 100 14 119 97
                                      • flatline
                                        • Apr 2019
                                        • 23
                                        • united states
                                        U11 SIO IT8987
                                        Pin14 3.25V EC_WRST
                                        Pin97 3V ACIN
                                        Pin100 16mV S5_ON
                                        Pin119 0V RSMRST#
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Loli Popu
                                          DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                                          by Loli Popu
                                          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                          12-13-2024, 03:28 AM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Bloodhoundje
                                          HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                          by Bloodhoundje
                                          I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                          I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                          After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                          I have desoldered the bios chip (GigaDevice...
                                          03-16-2024, 03:12 PM
