Asus x555LD touchpad not working
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3608
    • slovakia
    Hello. Have this Asus X55ld that have not working touchpad. dont have schematic or boardview so anybody know where to start searching for fault?
  • Jesse James
    • Sep 2018
    • 95
    Re: Asus x555LD touchpad not working
    Did you check in control panel if its enabled
    Does it show up in device manager
    I had Asus where guy was using aftermarket charger and in that case was trackpad issue
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      first download the boardview from this thread:
      https://www.badcaps.net/forum/showthread.php?t=60549
      then, follow the procedure mentioned in this thread to find the cause of the problem:
      https://www.badcaps.net/forum/showthread.php?t=75720
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3608
        • slovakia
        i did the measurement and all looks good. even compared to another board.
        have 3vs, 3.3v on data line, resistance looks good too. have spare touchbar thar not work too
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          so this is a strange kind of touchpad problem that does not give any clue. thus, more tests should be done to find a clue to discover what component is defective.
          • mosfetratus
            Sure Not
            • Feb 2019
            • 174
            • Resistron
            DRIVERS! I had same problem, trackpad wont work. Bugged drivers or something windows related.
            Uninstall drivers from device manager and remove trackpad software. Restart PC, it should install generic drivers.
            this asus notebook is total garbage. GT820M throttles with fresh thermal paste. Trackpad problems. Stupid motherboard design.
              • 21173
              The grounding tape thats used can break down over time.Solder some jumper wires
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3608
                • slovakia
                have spare flex. little longer but same wide.
                grounding tape?
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3608
                  • slovakia
                  how is touchpad identified in device manager?
                  • KenSea12
                    • Jan 2019
                    • Philippines
                    Try to set the default set-up in BIOS Setting Sir
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3608
                      • slovakia
                      allredy done. i was thinking about bios reflash
                      dont know if latop see that touchpad
                        • 21173
                        grounding tape?
                        Well, i call it grounding tape.Its the fabric conductive tape in the picture above the white sticker on the left (its an acer netbook).Without that tape or a jumper wire its erratic or doesn`t work at all .Theres another large GND pad on the right where i can run a jumper wire to the surrounding metal bracket .
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3608
                          • slovakia
                          solder a wire from big ground pad to gnd of board but nothing changed
                            • 21173
                            Ok, it was worth a try .
                            • mosfetratus
                              Sure Not
                              • Feb 2019
                              • 174
                              • Resistron
                              Device manager:
                              under, mouse and other pointing devices, should have name ASUS.
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3608
                                • slovakia
                                no, dont have
                                • mosfetratus
                                  Sure Not
                                  • Feb 2019
                                  • 174
                                  • Resistron
                                  no, dont have
                                  It should be asus smart gesture or asus support device (generic drivers).
                                  Try booting latest hirens CD with linux or mini windows 7/10, they should have generic drivers. To test if it's windows/drivers problem.
                                  because in my case it was exactly it - Drivers.
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3608
                                    • slovakia
                                    i ty boot latest ubuntu witout luck for working touchpad
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3608
                                      • slovakia
                                      Guys its look like a common X555LD problem. Have repaired another board and have same problem. Just replaced main mosfet and dport to lvds convertor IC.
                                      Does anybody have guide how to solve this problem?
                                      • caspian
                                        • Oct 2015
                                        • 1591
                                        • Laptop
                                        replace the two inductors which are located near the Touchpad connector on the mainboard. this may solve the problem.
