Touch pad and keyboard not working
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi I have ACER aspire 4730z JAL90 LA-4210P the keyboard and touchpad is not working at all. I dont know where to focus in repairing this kind of problem ..
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Touch pad and keyboard not working
    you need to measure voltage on the tp and kbd connector pins first
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      jp4 pin 7 has 3v
      jp7 pin 6 has 5v
      • piernov
        • Jan 2016
        • 4437
        • France
        Any liquid damage?
        Tried another keyboard?
        Working with external mouse/keyboard?
        Tried another operating system?
        Tried a BIOS update?
        • kostukas1985
          • 15
          • lithuania
          keyboard and touchpad not working only in windows or in Bios window to?
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            even in bios sir I cant boot on any bootable
            • petehall347
              • Jan 2015
              • 4428
              try external
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                try external
                not working sir ive tried flashing bios
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  not working in windows also in post bios
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    how can i fix this?
                    • fichamba
                      MSI GL75 Leopard keyboard (almost) not working - HELP
                      by fichamba
                      Hello everybody:
                      Let me put all the laptop's info before describing the problem:
                      BRAND: MSI
                      MODEL No.: MS-17E7
                      SKU: GL75 Leopard 10SEK-261XES-BB71075H16GXXDXX
                      MoBo: MS-17E71 VER. 1.0
                      This laptop arrived to fix the broken left hinge, due to a hit. The hinge was repaired, and when I went to check it out, everything worked well, but I observed certain artifacts (mainly random lines) in the screen.So I decided to remove the screen bezel again, and I saw certain damage to the main LCD harness.
                      This time I also observed that the right...
                      10-09-2024, 04:53 PM
                    • obelix24
                      Macbook Air 2020 (a2179) - touch id not working
                      by obelix24
                      Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                      I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                      02-09-2025, 12:57 PM
                    • Vliegenier04
                      Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
                      by Vliegenier04
                      Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
                      I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
                      Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
                      06-16-2025, 12:03 PM
                    • hopkok
                      Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                      by hopkok
                      Hi masters, I need your help.
                      I am working on Lenovo Legion 16ITHg6
                      Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                      INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                      My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                      AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                      Power LED is not working as well, power button working well.
                      UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                      Motherboard...
                      05-04-2025, 09:35 AM
                    • ronaldopdias
                      Dell Alienware x17 R1 - Keyboard not working
                      by ronaldopdias
                      Symptoms:
                      No keys work apart from F1, F7, F12 function keys such as keyboard brightness, touchpad enable/disable.
                      Keyboard RGB works okay and might be adjustable.
                      VERY occasionally it may function but most of the time it is dead.
                      The fault is down to the USB data lines not going low when the bus is idle. The keyboard connects over USB, so the issue on the USB data bus causes it to stop functioning.
                      The fix is to fit a 1K resistor to the daughterboard that the keyboard + trackpad connect to. The daughterboard is located beneath the battery. The resistor...
                      05-13-2025, 04:50 AM
