Help me understand this schematic
  • IamPritesh
    • Aug 2017
    • 356
    • India
    Can anyone please tell me the source of +5V_VCC1 on the schematic attached with this post.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: Help me understand this schematic
    looks like its just badly marked +5V switched from +5V_S5 by PQ62
    just diode probe its trace from it
    • piernov
      • Jan 2016
      • 4439
      • France
      As per datasheet, VCC (pin 3) is connected to PVCC (pin 19, VDD on schematics) through a 10 ohm resistor internal to the PM6686 chip.
      • IamPritesh
        • Aug 2017
        • 356
        • India
        I was hoping that this VCC input for PU9 is generated well before the voltage reaches the coils PL13 and PL14.
        maybe I am wrong...
        • IamPritesh
          • Aug 2017
          • 356
          • India
          That is some awesome information. In that case Pin19 is connected to LDO (6237LDO5 on schematic). So if I have 5V LDO , then I should also have the same on VCC (Pin3) but that does not seem to be the case if I recall well. I have 5V LDO but no voltage on +5V_VCC1
          • piernov
            • Jan 2016
            • 4439
            • France
            Maybe PC191 is shorted or PU9 is bad then.
            • Udemzy
              • May 2017
              • 164
              • Guatemala
              No voltage on pin2 and pin 32? Did you check impedance of the pin? Cos Ton will automatically generate from the ic.
              Check impedance otherwise replace ic.
              • IamPritesh
                • Aug 2017
                • 356
                • India
                IC replaced with a new one. Now I have LDO and 3VPCU
                BUT I do not have +3V , no MAIND signal and no 5V as well.
                Please refer to the image. I am having a hard time trying to figure out why 15VCPU is 10V .
                Please note PC191 is currently removed and I feel it should make no difference.
                • IamPritesh
                  • Aug 2017
                  • 356
                  • India
                  Any help what could be causing 10V instead of 15 volt on 15VCPU
                  • khaahk
                    • Dec 2013
                    • 818
                    • Estonia
                    Missing 5V from PU9?
                    Do you have s5_on? To explain missing 5V from PU9.
                    Dickson charge pump
                    https://www.youtube.com/watch?v=I4ED_8cuVTU
                    • IamPritesh
                      • Aug 2017
                      • 356
                      • India
                      Dickson charge pump
                      There is no S5_on. S5_ON is coming directly from SIO chip and this SIO CHIP does not have any VDD voltage.
                      SIO chip does have VCC voltage coming from 3VPCU. I was wondering if VDD is essential on SIO chip before S5_ON is generated ?
                      • khaahk
                        • Dec 2013
                        • 818
                        • Estonia
                        SIO VDD should come after maind signal, which in turn seems to come after run_on signal.
                        Does SIO give 3V to power button? After pressing power button does it give impulse to PCH (EC_PWRBTN# goes low for a short time)? Does PCH respond with pulling SLP_S4 and S3 high?
                        How much current is drawn before pushing power button and does it change?
                        Resistances on +3V and +5V rails - maybe there is low resistance after PQ62 and PQ45?
                        • IamPritesh
                          • Aug 2017
                          • 356
                          • India
                          There is only 1.5 volt on power button. Bios Chip pin1 has same 1.5 volt on pin 1 and around .6 volt on pin 8 of bios chip
                          There resistance on PQ62isa and PQ45 output is around 300 ohms.
                          What could be causing this, i am running out of ideas what to check.
                          • khaahk
                            • Dec 2013
                            • 818
                            • Estonia
                            How much current is drawn from adapter before pushing power button?
                            300 ohms seems a little low but not sure.
                            • IamPritesh
                              • Aug 2017
                              • 356
                              • India
                              Using a DC power supply it shows 0.03 Amp when I plug in the Adapter.
                              Could this be a case of faulty SIO chip ? Anything I can do test this chip ?
                              • khaahk
                                • Dec 2013
                                • 818
                                • Estonia
                                0.03A is a bit too much, but too little to find anything by heat i think.
                                Check if sio tries to read it's program from KU3, pin 2,5,6.
                                You can also inject directly 3v after PQ45 to see if anything heats abnormally.
                                Seems like a hard to find fault you got there.
                                • khaahk
                                  • Dec 2013
                                  • 818
                                  • Estonia
                                  Check PD27 & PD28 just in case 15V has to be also present at first.
                                  • edugimeno
                                    Help me understand this schematic Harman&Kardon tape deck (TD470)
                                    by edugimeno
                                    Hi there!
                                    Im trying to service an old Harman&Kardon tape deck (TD470) player, which after being put away for many years, is now lacking sound randomly (first time I tried it worked, called the owner and said it wasn't working for him, tried again myself and sound was gone)
                                    This intermitent issue led to to go straight to the PS & Caps...I found at least one voltage missing (sorry now I can't remember which one), and one of the 3 fuses in the PS was open (this is strange as an intermitent failure wouldn't relate to a blown fuse).
                                    First thing I suspected...
                                    09-27-2021, 07:27 AM
                                  • IamPritesh
                                    Help me understand this schematic about PROCHOT
                                    by IamPritesh
                                    Can you anyone explain what should be the ideal voltage for PROCHOT according to this schematic.
                                    I have no voltage on AD_IINP.
                                    On U8801 I have 5V on pin 5 and 0.537 volt on pin 3. No output voltage.
                                    Currently board is not triggering at all....
                                    02-23-2023, 03:24 AM
                                  • mkdj
                                    MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                    by mkdj
                                    About me, my goal and the equipment I (don't) have:
                                    I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                    About my issue and my goal:
                                    A friend of mine has a MacBook Air M1 A2337 that does not...
                                    04-03-2025, 08:28 AM
                                  • TinkerTron
                                    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                    by TinkerTron
                                    Hey everyone,
                                    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                    Instead, here's what's been bugging me so far:
                                    The schematic...
                                    03-06-2025, 02:03 PM
                                  • atunguyd
                                    Acer x163w Monitor PSU schematic
                                    by atunguyd
                                    Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                    The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                    03-05-2025, 02:08 PM
