Help me understand this schematic about PROCHOT
  • IamPritesh
    • Aug 2017
    • 356
    • India
    Can you anyone explain what should be the ideal voltage for PROCHOT according to this schematic.
    I have no voltage on AD_IINP.
    On U8801 I have 5V on pin 5 and 0.537 volt on pin 3. No output voltage.
    Currently board is not triggering at all.
  • mon2
    • 14677
    Re: Help me understand this schematic about PROCHOT
    https://www.analog.com/en/design-cen...y/prochot.html
    • IamPritesh
      • Aug 2017
      • 356
      • India
      So under normal scenario it should be low ? Also I do not have AD_IINP voltage (The datasheet says it should be 20 times the difference between the two points of current sensing resistor. )
      • mon2
        • 14677
        No, this is an active LOW signal since there is a '#' suffix.
        In digital logic, a '#' suffix means the signal is considered active if logic low. So if low, the processor is running hot.
        • mon2
          • 14677
          Remove all power. Measure the resistance across R8824.
          If present, next check the resistance of R8823.
          • IamPritesh
            • Aug 2017
            • 356
            • India
            Thanks for helping me with this. here are the readings..
            R8824 = 99.6K ohms if unsoldered from the board
            R8824 = 13K~24K ohms while it is soldered to board
            R8823 = 10.2 K ohms
            • mon2
              • 14677
              Pin 3 has the correct voltage:
              https://ohmslawcalculator.com/voltag...der-calculator
              Use the above calculator to confirm. Use the values from the schematic.
              • IamPritesh
                • Aug 2017
                • 356
                • India
                yes you are right. So what should be the output on PIN 4 of U8801 ? If understand it should be 5v when we have a higher voltage on PIN 1 as compared to Pin 3 . But the fact is PIN 1 has no volt at all. Resistance to ground on Pin 1 of U8801 is 0.586.
                • mon2
                  • 14677
                  Check if R0312 exists on your board.
                  Then measure the voltage to ground on each pin of R0312. This pull up must be present to pull the prochot# line to a logic high as the mosfet being driven by the comparator is OFF.
                  Effectively, this is an open drain or open collector driver.
                  There is a logic low if the mosfet closes when the gate voltage is high enough from the comparator.
                  Otherwise the prochot# line is floating so the external pull up resistor is required to define the open or floating logic state.
                  • IamPritesh
                    • Aug 2017
                    • 356
                    • India
                    R0312 has no voltage on either side .
                    • mon2
                      • 14677
                      Check if you have +1.0VO.
                      • IamPritesh
                        • Aug 2017
                        • 356
                        • India
                        Yes I do have +1.0VO on L8201
                        • mon2
                          • 14677
                          What is the voltage to ground of SUSB#_PWR ?
                          • IamPritesh
                            • Aug 2017
                            • 356
                            • India
                            No voltage on SUSB#_PWR
                            Also +12VSUS is showing as 15V
                            • IamPritesh
                              • Aug 2017
                              • 356
                              • India
                              Any other pointers on this issue please. Really appreciate all the help that has been given so far.
                              • mon2
                                • 14677
                                From what I see, you are missing VCCIO.
                                VCCIO is based on +1VO which you have.
                                The load switch that passes on this rail to become VCCIO is triggered by SUSB#_PWR. This trigger is from the EC (as SUSB_EC# ) and this signal is missing.
                                This path is from page 92 of the linked schematic.
                                Review the basics, with the adapter connected, what are the voltage to ground of each coil. Are you missing any voltages on these coils?
                                You have a type C power supply to power this board?
                                Is it the original and with the proper power rating?
                                Do you have a usb c meter to review the current and voltage being selected by the logic board?
                                • edugimeno
                                  Help me understand this schematic Harman&Kardon tape deck (TD470)
                                  by edugimeno
                                  Hi there!
                                  Im trying to service an old Harman&Kardon tape deck (TD470) player, which after being put away for many years, is now lacking sound randomly (first time I tried it worked, called the owner and said it wasn't working for him, tried again myself and sound was gone)
                                  This intermitent issue led to to go straight to the PS & Caps...I found at least one voltage missing (sorry now I can't remember which one), and one of the 3 fuses in the PS was open (this is strange as an intermitent failure wouldn't relate to a blown fuse).
                                  First thing I suspected...
                                  09-27-2021, 07:27 AM
                                • mkdj
                                  MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                  by mkdj
                                  About me, my goal and the equipment I (don't) have:
                                  I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                  About my issue and my goal:
                                  A friend of mine has a MacBook Air M1 A2337 that does not...
                                  04-03-2025, 08:28 AM
                                • TinkerTron
                                  Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                  by TinkerTron
                                  Hey everyone,
                                  I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                  Instead, here's what's been bugging me so far:
                                  The schematic...
                                  03-06-2025, 02:03 PM
                                • atunguyd
                                  Acer x163w Monitor PSU schematic
                                  by atunguyd
                                  Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                  The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                  03-05-2025, 02:08 PM
                                • Thetechdude
                                  MSI Ventus RTX 4080 16G Broadview schematic needed
                                  by Thetechdude
                                  Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                                  I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                                  Thanks.
                                  07-15-2025, 11:15 AM
