MacBook Pro A1708 screw guide?
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Good day everyone. My dad gave me a macbook pro A1708 i7 version and its in pieces... literally. But no it wasn't crushed or broken. He tried to replace the keyboard by himself, tried to disassemble everything and later realize it wasn't that easy. He gave up and decided to let me take over.
    I know I can replace the keyboard but the problem are the screws. Its all mixed up and I suppose some are missing. I honestly dont know where they go. Different sizes and lengths. I cant seem to find some info or guides from the net as they only show how to disassemble it. Maybe someone here have an idea on where the screws go. As of now I'm currently removing the keyboard. Dad already had the replacement keyboard which cost 140 bucks. I hope everything goes well, Thanks and have a great day everyone!
  • mosfetratus
    Sure Not
    • Feb 2019
    • 174
    • Resistron
    Re: MacBook Pro A1708 screw guide?
    you could find iFix it tutorial, so you can visual ideal where screws goes.
    • lezsimply
      The Wanderer
      • 657
      • Philippines
      Thanks! I already tried iFix. I can only see a few screws on the whole procedure. I emailed the person on youtube who took apart the same model I have. Just waiting for response. By the way keyboard is very hard to remove unless you grind the spot weld.
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • EpicFix
        MacBook Pro A1708 820-00840 stuck @ 5V, no power, no charging
        by EpicFix
        Hey guys, I need a little help here. I have a MacBook Pro A1708 820-00840 stuck @ 5V. Started off affecting just one port but now it's affecting both. Both CD3215 ics were replaced but the issue remains. One port does a loop and the other stays at a constant 5V. Both CD3215 have 3V incoming. I checked for PP3V3_G3H @ R3000, C3100 and C3108, R3001, C3200 and C3208. The weird thing is though that the ammeter shows the current draw (5V @ 0.5A) coming out from the port as opposed to it going in. Any ideas on helping me fix this?
        04-08-2025, 09:55 AM
      • 24gsm
        MacBook Pro A1708 install macos fail
        by 24gsm
        hi to all
        i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
        after enter to recovery and format hdd 1to .
        after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
        can help please
        Serial Number: FVFXP0U0HV2J
        Config Code: HV2J
        Find My Mac: OFF
        04-16-2025, 03:57 AM
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
      • AlexVG
        Macbook A1708 820-00840 not a start
        by AlexVG
        Hi everybody
        I have Macbook A1708 820-00840
        It goes through all steps to start
        exclude last steps power PPVCCCPU_S0G and PPVCCGT_S0G
        Besides, no exchange on
        CPU_VIDSCLK
        CPU_VIDSOUT
        However CPU_PWRGD is OK
        CPU_PROCHOT is down.
        I replaced SPI dump from here:
        https://www.badcaps.net/forum/troubl...n-me-pram-bios
        Unfortunately did't help me.
        Would...
        11-07-2024, 09:05 AM
