Hello, DV6700 , dead but when i plug the adopter the light come on only, i checked mosfet pq30 pin 5.6.7.8 19v pin 1.2.3. 0v pin 4 0v, but mosfet is ok
					Dv6700 dead, only adopter light in on
Re: Dv6700 dead, only adopter light in on
Here is schematic, thanks for your helpAttached FilesComment
u r senior member. u must know that u must start with measure charger ic pins
but is it worth it? that nvidia NB was same shit like nvidia GPUsLast edited by ktmmotocross; 02-12-2019, 01:43 PM.Comment
Hello, sorry i thought i said i tested the pq30 which i got only 19v on pin 5.6.7.8. pin 1.2.3. no output even pin 4Comment
yes, max8724 is the chargilng ic for this laptop, meanwhile on this board i found this components short ..[ pu8 TL331 ] and pq27 IMZ2, i dont have exact numbers , which one can i use as replacement ? IMZ2 is shoted all the legsComment
I already removed pq27 there was no short on board, when i tested outside circuits still shortingComment
I think it's this section that's acting as a charge pump.
Not exactly sure how it works but I think the opamp circuitry around PU8 is an astable multivibrator and PQ27 is some sort of "buffer" to charge/discharge the capacitor PC88 and not affect the characteristics of the astable multivibrator.
This just creates an oscillator for the charge pump (centered around PD12, the dual diode on top right, I cut the markings in the screenshot…) to workOpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Thanks piernov for the explanation i thought PU8 was a Operational Amplifier.I think it's this section that's acting as a charge pump.
HISPECK the curcit you must get rid of the shortLast edited by Techtiger; 02-14-2019, 11:20 PM.Comment
			by esqmoooHello everyone.
This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
I tried long pressing on the power button, after several seconds it would go off then when the button is released... -
			by PatanNeed help here...
I'm new on the forum and I'm not professional in electronics so i ask sorry in advance for eventual errors...
As title says, i have a LA-H323P dead.
Now, little background.
The computer was working fine, just seems that the cable of screen was dying because it had the classic color problem, sometimes green, sometimes violet, sometimes perfect, but anyway working.
When i opened it the battery was so fat that was seriously near to explode.
So i removed the battery... and turned on the notebook... that was, again, working perfectly fine....11 Photos -
			by Rav_tangleHi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
is this... -
			by mecha1166I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
			by sam_sam_samSee pictures for type of laptop computer
I checked switching power supply brick 19.2 volts multi meter only
No booting without switching power supply connected
Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
What the heck is going on here...-
 - Loading...
