N5010 colour issue after conversion
  • pratyush
    • Sep 2018
    • 69
    • India
    Facing orange colour issue on screen after conversion discrete to uma..what will be possible solution..
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: N5010 colour issue after conversion
    very likely PCH faulty if those RN connected to lvds connectors are ok and connector itself is not damaged.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3628
      • slovakia
      do u know that display is 100% ok? looks like there are many issues on it
        • 21968
        Pressure marks on screen,replace it. test on hdmi .
        • pratyush
          • Sep 2018
          • 69
          • India
          Screen nd display cable already checked...
          • pratyush
            • Sep 2018
            • 69
            • India
            I checked for RN connector rn7701 which seems to be for colour that is okk...
            Plzz mention other rn connector that should be checked...if possible
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3628
              • slovakia
              try to heat up UMA to 130c to check broken ball
              • Spider1211
                Dell N5010 display issue after UMA conversion
                by Spider1211
                Hey guys, need help figuring out what's causing the following issue.
                I have a dell N5010 which had a bad GPU chip and a UMA conversion was performed.
                Initial conversion was done per this video: https://www.youtube.com/watch?v=cq8r920tW64
                After conversion, laptop boots and display comes on but once windows starts loading, it becomes all fuzzy/dotted. I initially though it could be a driver issue, so I removed the HDD and booted into BIOS settings. Image was not fuzzy but some letter jitters (like dancing dots at the edge of the letters) was visible....
                05-15-2021, 04:50 PM
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                🛠 Original Issue
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                by ugamazing
                12-17-2024, 07:05 PM
              • shahnld
                Lenovo legion 5 pro startup issue
                by shahnld
                Good day Experts
                I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                08-24-2025, 12:31 PM
              • ahmarzo
                Acer laptop battery draining issue
                by ahmarzo
                Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                08-02-2025, 06:39 AM
