HP 450 G2 Shorted
  • Jesse James
    • Sep 2018
    • 95
    HP 450 G2 Shorted
    Hi I have a board that is shorted and need some help. When plugged in power light and caps light always on. I have traced it down to an area where 3.3v is shorted but need to find the source of short. The 19v and 5v look ok.I have uploaded schematics and pg 47 PU301 pin 9 shorted as well as PL303 PC314 and PJP303. Some guidance would be helpful
    Board LA-B181P
    Rev: 1.0
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: HP 450 G2 Shorted
    Left one Pad of PL303 & put your multimeter in diode mood and test both sides of the Coil for value or else remove PJP303 JUMPER With the help of soldiering iron and test Diode mood for value both sides
    If the short is on +3VDSP side those Fets PQ301/PQ303 might be your case if not you have to test all components with that line 7caps & 1 Resistor
    • Jesse James
      • Sep 2018
      • 95
      I removed PJP303 jumper and short is on 3vds side. I will post back when I find more
      • razu
        • Jan 2015
        • 218
        • Bangladesh
        Remove 3.3volt coil and Inject 3.3v by lab psu.......then u look the meter of psu.........
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3609
          • slovakia
          tahat rail is main rail for aics for all over the board , so inject 3V with current 2A and find burning component
          • reessi
            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
            by reessi
            Hello:
            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
            I started on the ACER:
            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
            10-29-2024, 11:31 AM
          • Yanleb
            Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
            by Yanleb
            Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
            I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
            D608, good
            D618 RF101L4S, good (See warning 1 below)
            D619 RF101L4S, good (See warning 1 below)
            D865 RF101L4S, shorted (See warning 1 below)
            IC464 Inverter HA MC74HC1G14, shorted...
            03-09-2020, 12:00 AM
          • modtool
            HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
            by modtool
            Hi to all,
            the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
            I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
            I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
            04-01-2025, 08:22 AM
          • BalkanBoy
            Dead Razer Blade 14 2022, shorted CPU?
            by BalkanBoy
            today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
            Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
            I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
            Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
            I removed coil and injected 0.7V, it draw around...
            09-27-2024, 12:44 PM
          • barry101
            Apple 820-3662 VCore shorted to ground.
            by barry101
            Hi, Would appreciate some help.
            I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
            Get charger light but no fan spin or chime. No liquid damage.
            Found PPBUS and VCORE both shorted to ground. Other rails were ok.
            Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
            With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
            Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
            06-24-2025, 07:34 AM
