Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
  • rccrasher65
    • Mar 2014
    • 626
    Re: Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
    Originally posted by BlueMidnight
    Alright, hope you have a smooth recovery.
    Challenge accepted
    Thank you, much appreciated. I'll try to get back at as soon as I can.
    • rccrasher65
      • Mar 2014
      • 626
      just checking in, still not able to do much!
        • 22216
        Hope you get well soon, you can`t do much without your health,that has to come first .
        • rccrasher65
          • Mar 2014
          • 626
          Thank you!
          • rccrasher65
            • Mar 2014
            • 626
            well after a long shoulder recovery, I think I can get back at it with programming, mod was done. If my friends out out there, give me a holler!
            • BlueMidnight
              • Jan 2015
              • 489
              Welcome back. Hope you're feeling better. Please continue from post 316.
              • rccrasher65
                • Mar 2014
                • 626
                Feeling much better, still trying to get winzip to open that rar file, once I get that things will start I guess. I have no idea why I'm having such a hard time with that. I think I might have to subscribe to winzip for it to open. It is certainly not opening any other way I've tr. Suggestions.
                • rccrasher65
                  • Mar 2014
                  • 626
                  I finally got those files to open, and are in a folder. I guess I'm ready to program that reader. Any instruction on how to do that. looked on y-tube, can't understand most of them. Thanks
                  • Stevedb
                    Stevedb
                    • Feb 2018
                    • 624
                    • Belgium
                    #329
                    Hi
                    You must just open colibri and detect the chip. Then just read it then open the file and write.
                    https://youtu.be/cDek8OnoyaA
                    Good luck
                    Best regards
                    Steve
                    • BlueMidnight
                      • Jan 2015
                      • 489
                      And you can try it out on one of the other boards you have so you don't have to worry about making mistakes. Try connecting that little clothespin-style clip to the chip so you don't have to desolder anything. Make sure the red wire goes to pin 1 on both ends.
                      The first step is always to press the "ID" button to detect the chip model. It will list what model it found in the text box on the left. Make sure it matches the actual chip.
                      Next, do some practice reads and writes. Click the read button and make sure data from the chip shows up on the right side of the window. Then, without closing the program, write to the chip. The write button will always write the data that is showing in the window. So, in this case, it will write the data it had just read in the previous step.
                      Practice that a couple times.
                      Next, try to save a backup of a chip:
                      1. Open program
                      2. Click ID
                      3. Click read
                      4. Click save (second button from the left) and choose a file name and location you will remember later
                      Finally, try writing from a file:
                      1. Open program
                      2. Click ID
                      3. Click open (first button on the left) and select the backup file you just made
                      4. Click write
                      Once you are comfortable with all of the above, you can try using the real motherboard. Read the chip and save it to a file. We'll continue from there when you reach that point.
                      • rccrasher65
                        • Mar 2014
                        • 626
                        1. Open program
                        2. Click ID
                        3. Click read
                        1. Open program
                        2. Click ID
                        4. Click write
                        Yea it will definately be a while, completely lost. So I do not actually have to install anything on the reader, just put it into my laptop, connect to board using the clip cable, open the calibri program, and try to read chip?
                        • BlueMidnight
                          • Jan 2015
                          • 489
                          See my previous post and the other posts it links to. You have to connect the programmer to the PC, install the Windows driver, connect the programmer to the chip on the motherboard, and run the programmer software.
                          • rccrasher65
                            • Mar 2014
                            • 626
                            I'll need some time to figure this out. I'll get back to you when I know what I'm doing with all this.
                            • rccrasher65
                              • Mar 2014
                              • 626
                              I went to open and install drivers from the file, and its says file not found. Tried both programs same thing file not found.
                              • rccrasher65
                                • Mar 2014
                                • 626
                                what file actually contains the driver. When I plug reader into usb port it shows up on my devices installed. Does that mean I installed the driver? PC recognizes the programmer, from what I'm seeing. I didn't try to connect a board yet. Still don't know if I installed the driver.
                                • rccrasher65
                                  • Mar 2014
                                  • 626
                                  Bump
                                  • Stevedb
                                    Stevedb
                                    • Feb 2018
                                    • 624
                                    • Belgium
                                    #337
                                    Hi
                                    Normal you got an notification if the programmer is connected. Underneath the screen.
                                    Then you know your driver is installed and pc recognised the programmer.
                                    Regards
                                    Steve
                                    • rccrasher65
                                      • Mar 2014
                                      • 626
                                      Originally posted by Stevedb
                                      Hi
                                      Regards
                                      Steve
                                      what file is the driver in. when I click on the one that says it, its says that the file is not found.I do believe there are 5 or 6 files in that Cipri programmer file. I don't know if I'm making Cense here.
                                      • BlueMidnight
                                        • Jan 2015
                                        • 489
                                        Inside the main "Colibri_CH341.rar" archive, there is another archive named "CH341PAR drivers.rar". Inside that archive is a setup.exe program you can run to install the drivers.
                                        • rccrasher65
                                          • Mar 2014
                                          • 626
                                          my setup. exe program says driver install failure when I try to install drivers.
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • someonenotyou
                                            HP ProBook 445 G7 no POST only on battery
                                            by someonenotyou
                                            Hi.
                                            I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
                                            When I attach DC Jack, the laptop will charge the battery and switch on.
                                            And now the strange part:
                                            1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
                                            2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop...
                                            06-30-2025, 01:24 AM
                                          • Jacksoft
                                            HP ProBook 440 G6 infinite orange blinking
                                            by Jacksoft
                                            I have an HP ProBook 440 G6 with DAX8JMB16E0 REV. E motherboard that got BIOS bricked after maaany bootloops caused by Window's BCD. I made a dump of the actual BIOS and written a found one.
                                            The PC worked but it was very slooow to show HP logo in first place.
                                            A friend of mine gave me another BIOS for this series and after the flash it powered on (white led on power button) but after few second shutted down and start blinking orange infinitely on the LED near the AC adapter connector on the side.
                                            The laptop doesn't power on anymore, and the blinking led happens...
                                            08-29-2025, 01:24 AM
                                          • stevenallauca
                                            HP laptop does not charge the battery, the light turns amber and then changes to white.
                                            by stevenallauca
                                            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                            - ACN (BQACN) 19.6v
                                            - ACP (BQACP) 19.6v
                                            - CMSRC (BQCMSRC) 19.6v
                                            - ACDRV...
                                            09-23-2024, 11:30 AM
