missing 5/3 volt PCG-61A11W
  • khelane
    • Apr 2015
    • 170
    • xxxx
    The SONY PCG-61A11W laptop had a 19V .after checking that the C4906 was burning, i changed it. 19 v circuit is clear. but i did not have 3 and 5 volt. after checking i replaced PU4103 (RT8223M) and laptop turn on. laptop worket 3-4 hour without problem but suddenly turn off !! i missed 3 and 5 v . now i connect charger 3 and 5 v present but next 1 or 2 Second will be disconnect.
    now i replaceD new IC RT8223M and motherboard go turn on but next 2 3 hour go offfff.
    The main problem with the device is that the circuit 3. It's not 5 volts while I'm sure of the safety of IC. Sometimes, the voltage is 3.5, but it is cut short soon.
    Accept my apology for bad speak english . (I'm learning)
    TNX
  • ugamazing
    820-02020 PPBUS_AON missing
    by ugamazing
    Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
    Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
    02-05-2025, 04:21 PM
  • jpreza
    Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
    by jpreza
    I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
    Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
    It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
    Looking at the card, it appears to be missing the following:
    1x 1.0uH inductor - orange square
    2x...
    11-01-2024, 10:54 PM
  • gurj1979
    Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
    by gurj1979
    Hey guys.
    Need help with this one.
    Fan not spinning due to missing PWN Fan signal.
    Also 5 seconds from powering up it freezes, unless in BIOS.
    But as soon as Windows starts to load, it will freeze.
    CPU is COLD / Room temp when it freezes.
    I've replaced the CPU, same problem.
    Replaced SIO/KBC IT8987e and reprogrammed - same problem.
    Replaced fan - same problem.
    Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
    Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
    08-19-2024, 05:22 PM
  • salopian
    Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
    by salopian
    Hello. I would need some advice please.
    My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
    He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
    I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
    I have already replaced the logic board with another...
    02-27-2021, 07:30 AM
  • ein_individuum
    Missing Capacitator Intel I9-12900KF CPU
    by ein_individuum
    I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
    I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
    Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
    08-06-2025, 01:36 AM
