hp 14-am096tu system fan error 90b
  • Romy2018
    • Sep 2018
    • 174
    • japan
    Re: hp 14-am096tu system fan error 90b
    @SMDFLEA the two caps near fan connector is connected to ic with a marked S32B 5388
    • Romy2018
      • Sep 2018
      • 174
      • japan
      @ON/OFF the board id isINERINL-6050A2822501-MB-A01
      • Romy2018
        • Sep 2018
        • 174
        • japan
        @KMMOTOCROSS the 5 leg chip has marke 58IC
        • Romy2018
          • Sep 2018
          • 174
          • japan
          anyone please help on this
          • Romy2018
            • Sep 2018
            • 174
            • japan
            anyone can help on this please still I havent solved this issue
            • Techtiger
              • Oct 2014
              • 1602
              • france
              #26
              Test Voltage on all pins of this IC & mesure resistance Diode mode to GND all pins
              • Romy2018
                • Sep 2018
                • 174
                • japan
                #27
                the voltages on each pin1=0v pin2=0v goes to ground on continuity pin3=0v
                pin4=3.3v pinv=0v. on diode mode pin1= 0.500 pin2=0 pin3=0.700 pin4=0.600 pin5=0.500
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  #28
                  Assume pin 2 is the GND of this IC the rest of the pin's seams to be fine
                  If Pin 4 is the enable Signal to Drive Swatch on +5V to Fan & HHD you are missing +5V input
                  What if you put a jumper +5V to fan & HHD and see if the problem goes off
                  Replace those 2 caps if you can
                  i found a 5 leg chip near on dvd connector the pin with the red marked is connected to the caps on the hdd and fan side if you inject 5v there the fan spins
                  What pin of the 5 Leg ic did you inject 5V ?
                  • Romy2018
                    • Sep 2018
                    • 174
                    • japan
                    #29
                    if i injeck 5v on pin 5 on the ic the fan turns on because this pin is connector to the capacitor near the hdd connector and two caps near the fan connector
                    • on/off
                      • Oct 2016
                      • 333
                      • Indonesia
                      #30
                      I think this series have 2 variant model, one fanless and next with fan.
                      Link HD image:
                      https://drive.google.com/open?id=0Bw...0hQTHdYaE1VQUU
                      Credit to Rimas
                      • Sus256
                        HISENSE 65E7KQ PRO - no boot
                        by Sus256
                        Hi all!
                        HISENSE 65E7KQ PRO
                        RSAG7.820.13512 - chassis
                        MT9618BAATAB - cpu
                        RSAG7.820.12059 - power
                        HD650Y3U77 - panel
                        KLM8G1GETF - emmc
                        The TV does not turn on, the standby indicator is on. All voltages are present.
                        Emms is dead. Not readable, not detected.
                        Replaced emmc.
                        But with another dump there is no launch
                        Terminal log
                        UART
                        AC_ON
                        RPMB key is not yet programmed
                        HASH1_VERSION=0x00000000 64bit
                        E-B
                        FDE enabled
                        layout pattern onebin by SAR7,0...
                        06-01-2025, 02:11 AM
                      • Superbee_dad
                        Sharp 80” long short flash backlight error - Help
                        by Superbee_dad
                        Hello Sharp TV experts
                        Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                        > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                        > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                        01-24-2025, 11:51 PM
                      • Maalobs
                        Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
                        by Maalobs
                        I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
                        The relevant service manual for the chassis is available here.
                        The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
                        When I short the SDM to ground I get the layer-2 error code 53.
                        The inside of the TV has no damaged components and no swollen capacitors.
                        In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
                        04-02-2019, 01:15 PM
                      • medinfo
                        Mac T2 after update(There was an error activating your device)
                        by medinfo
                        Macbook Pro 2019 T2
                        iCloud OFF
                        MDM unlocked by changing Serial Number
                        worked fine but after latest update see (There was an error activating your device. Please try again).
                        Erased and boot in internet recovery, same error.
                        changed to original serial number (iCloud OFF & MDM ON), same error.
                        tested with others serial number, same error.
                        tested (CMD+R), (Option+CMD+R), (Shift+Option+CMD+R), same error
                        Revived and restored by Apple Configurator and same error.
                        Any help ?
                        12-31-2023, 02:04 PM
                      • rmjimenez455@gmail.com
                        Sumsour station 8586D error H-E
                        by rmjimenez455@gmail.com
                        Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                        09-07-2024, 09:33 AM
