Fixing long screw damage on plastic
  • myth77
    • Feb 2017
    • 380
    • Croatia
    No matter how hard i try sometimes when i put laptop back together i mix some screws... as a result i get long screw damage on plastic on the other side of laptop, almost every time near the keyboard of the laptop....It looks like bubble and its very annoying to see.
    Is there any way to flatt back that plastic bubble? i was thinking maybe with heatgun on low and with little preasure...but i am afraid i will do even more damage..
    Any expirience here?
    • 21186
    Re: Fixing long screw damage on plastic
    Buy yourself a large magnetic mat and layout the screws in the same pattern as where the screws came out from
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Using low heat/hot air temp and applying a slight pressure with a flat surfaced tool will work. Just ensure where the heat is applied wouldn't cause any additional damage to components etc. This works for me all the time.
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        There is a high probability of having more damage by applying heat to the plastic. It would be useful if I see a photo of it.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3608
          • slovakia
          no tools needed. just good memory
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Ha ha. Thats perfect.
            • dj_ricoh
              • 2073
              today i made a new friend!
              its called GORILLA GLUE
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                She certainly is a great friend.
                • myth77
                  • Feb 2017
                  • 380
                  • Croatia
                  It looks like this..this is asus g751
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3608
                    • slovakia
                    sry mate but if u gonna try something it will be worse
                    • MJ-meo-dmt
                      • May 2016
                      • 186
                      • South Africa
                      hahahahahahahahahahaha
                      Agreed with the others just learn the screw sizes and length. And learn where they go when you take them out. And in mind when you put them back imagine the inside of the case and then think to yourself would screw x make sense here or there I mean just taking the length of the screw and where you are putting it if its too long it would be fairly obvious.... This you learn by taking many many many laptops apart. I don't even bother anymore with the screws... I'm a pile of screws guy... Don't get me wrong I have made those mistakes in the beginning but never again. You should take an old case and learn to feel the torque when you start going into the plastic and don't use big screw drivers for tightening because you have way to much torque.
                      It comes with time... but also use your head/mind and simply remember. Don't just do without care!
                      while alive { live(toFullest=true) }
                      • myth77
                        • Feb 2017
                        • 380
                        • Croatia
                        I tried to upgrade myself to faster ddr4 memory but all i get is error "your system is just not compatible...."
                        ok, thx to all, i will just have to be more organised...
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • Prott
                          PS5 - long screw damage, via to ground layer short?
                          by Prott
                          Hello dear Badcappers,
                          I came across a PS5 that was longscrewed. The screw went through the HDMI IC (which I replaced + repaired the traces it damaged), however the screw also bend the board and slightly cracked it on the other side. It still seems like it could be fixable though as the area might not have lots of traces going through it (fingers crossed).
                          Can somebody, please, measure their board and tell me if my assumption of an inner short between the via and ground layer is correct? These 3 pads have almost no resistance. I would like to make sure those are not some data...
                          07-27-2024, 08:54 AM
                          Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                          The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                          Securing a good thermal interface between...
                          10-07-2024, 04:35 AM
                          by momaka
                          03-15-2023, 10:17 PM
                        • SuperJames
                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                          by SuperJames
                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                          Specs
                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                          Backstory
                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                          10-23-2023, 04:09 PM
