LA-9001p black screen
  • pratyush
    • Sep 2018
    • 69
    • India
    Working on this mobo....Black screen
    Flashed bios, checked voltage on every coil all are OK
    checked Ram voltages 1.5v , vtt pin no.201 ok, Vtt_ref at pin 1 Okk, pin199 3.3v Okk pin no. 30 also ok
    What will be possible solutions?
  • pratyush
    • Sep 2018
    • 69
    • India
    Re: LA-9001p black screen
    Plt_rst pin13 also present
      • 20789
      Check U5 RTD2132S . http://*******/viewtopic.php?f=58&t=72780
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Where u r measuring plt_rst?? On wifi mini connector?? If so its not pin13
        • pyry
          • Dec 2015
          • 37
          • Mexico
          Plt_rst means if on pin 13 of the kbc there is 3.3v
          • pratyush
            • Sep 2018
            • 69
            • India
            at pin no.13 KB9012 and it is present 3.3v
            • pratyush
              • Sep 2018
              • 69
              • India
              Also checked U15 U53 U54 nd Q91 at page 34, these are all working good.
              • pratyush
                • Sep 2018
                • 69
                • India
                Thanking you....for yr replies.
                • pyry
                  • Dec 2015
                  • 37
                  • Mexico
                  Check the JLVDS1 display connector
                  pin 1 + LEDVDD 19v
                  pin 7 DISPOFF # 3.3v
                  pin 8 INVT_PWM 3.3v
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Is the mb with dedicated graphics?? Since you are getting PLt_RSt means almost everything is ok in power sequence. Perhaps cpu reset problem. Might be onboard amd processor is bad.
                    • pratyush
                      • Sep 2018
                      • 69
                      • India
                      One more thing I missed to mention when I remove ram ram beep is coming
                      • pratyush
                        • Sep 2018
                        • 69
                        • India
                        pin 1 + LEDVDD 19v
                        pin 8 INVT_PWM 3.3v
                        19v is okk
                        but pin 7 DISPOFF# - 0v
                        pin 8 INVT_PWM - 0.4V
                        this reading done without lvds cable inserted.
                        Nd one more thing i am also not getting +LCDVDD at Q71.
                        • pratyush
                          • Sep 2018
                          • 69
                          • India
                          Ya, this mb is with dedicated graphic card.
                          • pratyush
                            • Sep 2018
                            • 69
                            • India
                            I always stuck in this situation Onboard processor is bad is there any way to confirm directly I take many hours and at the end come to this stage.
                              • 20789
                              Keep the LVDS connected .Did you check U5 ,the ******* post has a chart with the working voltage from a good board.
                              • pratyush
                                • Sep 2018
                                • 69
                                • India
                                there will many mismatch of the voltage of o/p RTD3132s as suggested by ******* that means it may be faulty...but i don't have same working IC.
                                • pyry
                                  • Dec 2015
                                  • 37
                                  • Mexico
                                  19v is okk
                                  You have to make the measurements with the lvds cable connected.
                                  • pyry
                                    • Dec 2015
                                    • 37
                                    • Mexico
                                    Lcd power circuit
                                    3 volts not 19v I was wrong
                                    • HTR-Informatique
                                      by HTR-Informatique
                                      02-09-2025, 06:51 AM
                                    • howardc64
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
                                    • DaniK
                                      Acer Aspire E5-574-52RH - black screen
                                      by DaniK
                                      I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                      Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                      Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                      Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                      The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                      Symptoms are:
                                      - random black screen after displaying Acer logo...
                                      02-21-2024, 06:27 AM
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • Swedishpower
                                      Dell G3 15 3500 black screen
                                      by Swedishpower
                                      Hello
                                      I have search everywhere for a solution for my problem, but cant find it anywhere.
                                      When I was away to trow some garbage i always look in the electronic bin.
                                      and this time i find a laptop.
                                      Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                                      the lamp for charmig is white.
                                      Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                                      but no Dell logo.
                                      I tryed with a hdmi cable to another screen, still black.
                                      I started to search solution and tryed...
                                      07-06-2025, 06:18 AM
