Power problem in Sony mbx-266
  • vickey_vip
    • Mar 2016
    • 134
    • India
    Hi guys I need a help in repair of Sony Z50CR MB S1202-2 MB SONY MBX-266. It's not powering on I checked I get 19 volt on first input MOSFET which is pu4001 but it not given output voltage and I checked 3 and 5 voltage ic pu4103. Ic getting VCC 19 volt on pin number 16 but no voltage output on pin 7 and 24 means no 3.3 and 5 voltage comes. So I replace it with working mb ic and also replace battery charging ic But no result. What should I check now any expert legend help me I very appreciated. Thanks and ignore my bad english
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: Power problem in Sony mbx-266
    For this model it's very hard to find the exact schematic .
    So it's very difficult to help you.
    If PU4103 (RT8223M ? ) receive 19V why you have changed the charger ic ? and PU4001 receive 19V on drain but probably it's not driven from the IC.
    PU4103 start only if on pin 18 ENC there is an enable signal .
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Have you done cmos reset?? Sony mb are notorious for that when 19v doesnt goes to pin5-8 of dc in mosfet.
      • vickey_vip
        • Mar 2016
        • 134
        • India
        Check attached schematic it very close to this model and how can I check enable signal ? I don't have oscilloscope
        • vickey_vip
          • Mar 2016
          • 134
          • India
          I try but no power on
          • vickey_vip
            • Mar 2016
            • 134
            • India
            And cpu high side voltage on Pu4401not present
            • jasko_jacker
              • Oct 2014
              • 1137
              • italy
              Enable signal should be high 3.3v use a multimeter , first check 19V are present on PR4004
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3587
                • slovakia
                u dont need schematic for basic measure. u need datasheet of charging ic
                • vickey_vip
                  • Mar 2016
                  • 134
                  • India
                  On enable signal no voltage present and 19v present on PR4004 but pr4004 connected to directly DC Jack and in schematic pr4004 connected to pu4001 pin number 123
                  • Chrissygizmo
                    Sony KD-55XG9505 lines on screen problem
                    by Chrissygizmo
                    Hello again everyone,
                    This is my latest mission, to try getting this Sony tv back to normal working order…
                    I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                    02-19-2025, 11:31 AM
                  • crackedprint
                    Sony HCD-HX80R Amplifier Volume Control Problem
                    by crackedprint
                    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                    I have tried a Cold Reset as per the service manual.
                    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                    I have looked all the way through the service manual and tried many online...
                    01-21-2025, 12:18 PM
                  • retrorepair
                    SONY KDL-40P3600 Picture Problem
                    by retrorepair
                    Hello gurus, hope you can assist me...
                    I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                    I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                    Thanks in advance.
                    10-11-2024, 05:12 PM
                  • YasaCh
                    sony kd-49xf9005 4 red blinking problem
                    by YasaCh
                    Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
                    05-05-2025, 08:40 AM
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
