Hi guys I need a help in repair of Sony Z50CR MB S1202-2 MB SONY MBX-266. It's not powering on I checked I get 19 volt on first input MOSFET which is pu4001 but it not given output voltage and I checked 3 and 5 voltage ic pu4103. Ic getting VCC 19 volt on pin number 16 but no voltage output on pin 7 and 24 means no 3.3 and 5 voltage comes. So I replace it with working mb ic and also replace battery charging ic But no result. What should I check now any expert legend help me I very appreciated. Thanks and ignore my bad english
Power problem in Sony mbx-266
Tags: None
Re: Power problem in Sony mbx-266
For this model it's very hard to find the exact schematic .
So it's very difficult to help you.
If PU4103 (RT8223M ? ) receive 19V why you have changed the charger ic ? and PU4001 receive 19V on drain but probably it's not driven from the IC.
PU4103 start only if on pin 18 ENC there is an enable signal .Last edited by jasko_jacker; 09-27-2018, 04:44 PM. -
Have you done cmos reset?? Sony mb are notorious for that when 19v doesnt goes to pin5-8 of dc in mosfet.Comment
Check attached schematic it very close to this model and how can I check enable signal ? I don't have oscilloscopeFor this model it's very hard to find the exact schematic .
PU4103 start only if on pin 18 ENC there is an enable signal .Comment
u dont need schematic for basic measure. u need datasheet of charging icComment
On enable signal no voltage present and 19v present on PR4004 but pr4004 connected to directly DC Jack and in schematic pr4004 connected to pu4001 pin number 123Comment
by ChrissygizmoHello again everyone,
This is my latest mission, to try getting this Sony tv back to normal working order…
I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried... -
by crackedprintI have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
I have tried a Cold Reset as per the service manual.
I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
I have looked all the way through the service manual and tried many online...-
by retrorepairHello gurus, hope you can assist me...
I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
Thanks in advance.2 Photos -
by gurujiHello
I this Sony mbx-266 it powers
on all the voltages are normal the strange part iOS the caps key num key works which shows the machine has booted but no video at all internal dp and the ext vga or hdmi.I have changed the bios but same issue. What do I check ?? -
by YasaChSony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
- Loading...
