Laptop's AC adapter turns off when connected, corrosion on power-related components
  • kodox
    • Jul 2017
    • 327
    • Indonesia
    #41
    Re: Laptop's AC adapter turns off when connected, corrosion on power-related componen
    if i may share my experience here, finding shorted mosfet on the circuit is somehow a bit tricky. my method when using a multimeter, using continuity test then probe the electrolyte condensator after the choke (usually marked PLxx on mainboard), when probing those electroyte condensator is beeping, pay attention to value showed on multimeter (i use digital one), if the value less then 0.15 its 70% mosfet shorted to make sure 100% the mosfet is shorted, unsolder the PLxx, measure the mosfet side with ground and it should be beeping & the value less then 0.9 if the mosfet is the cause of shorted
    • fireaza
      • Sep 2018
      • 48
      • Japan
      #42
      There's a few components marked "PL-something" on this board. The ones with only 1 digit (i.e "PL4") are small components, while the ones with 3 digits (i.e "PL700") are large components, so I'm assuming the large ones are the ones you're talking about?
      In that case, here's the ones I found and what they display on the multimeter when probed:
      PL700 = "-008"
      PL701 = "-008"
      Pl100 = "-002"
      PL102 = "-002"
      PL101 = "-002"
      Is any of these helpful? Keep in mind, I still have the two mosfets and two solder bridges from before de-soldered!
      • kodox
        • Jul 2017
        • 327
        • Indonesia
        #43
        PL700 = "-008"
        PL701 = "-008"
        Pl100 = "-002"
        PL102 = "-002"
        PL101 = "-002"
        are you probed it with one lead of the multimeter to ground or both of the leads to the those inductor (PLxx)? i assumed you probed it with both lead of the multimeter to those inductor, because the value is very low.
        measure again with one lead of the multimeter connected to ground and the other to inductor
        • fireaza
          • Sep 2018
          • 48
          • Japan
          #44
          Oh, OK. In that case, here's those components from before but with one probe on ground:
          PL700 = "477"
          PL701 = "002" (also makes a beep sound)
          PL100 = "002" (also makes a beep sound)
          PL102 = "489"
          PL101 = "484"
          Does this help? Some of the components are behaving differently so I'm hoping this means we're on the right track! As before, I still have those two mosfets and solder bridges removed, so this might be expected behavior for when these components are missing!
          • kodox
            • Jul 2017
            • 327
            • Indonesia
            #45
            PL100 & PL701 is too low, you had multiple shorts in this case, try remove PL100 fisrt. after it's removed, measure using continuity test again with one lead to the ground and the other lead to PL100 pin 1 and after that to pin 2 of PL100 which one is the lowest value & beeped? if the lowest value on the pin that connected to mosfet, replace those mosfet. if the lowest value not on the mosfet side you should see the schematic to find what the load is, but i'm hoping not the load that make the short.
            • fireaza
              • Sep 2018
              • 48
              • Japan
              #46
              OK, it sounds like we're getting somewhere! Should I re-solder the two mosfets and the two solder bridges before I remove and test PL100? I've left these removed just in case, but it sounds like they will need to be in place based on what you said.
              • kodox
                • Jul 2017
                • 327
                • Indonesia
                #47
                it's okay, don't put back them for now. focus on those inductor that you've probed & beeped...
                • fireaza
                  • Sep 2018
                  • 48
                  • Japan
                  #48
                  OK, PL100 has been removed! I accidentally dropped it onto my workbench, and since it was hot, it now has some of the rubber sheet from my workbench melted to it :/
                  Now for testing, I'm not sure how you tell which pad is 1 and which is 2. One of the pads has 3 short lines coming from it, so I think this indicates something, so this is what I'll be using here!
                  OK, here's what's happening when I test the solder pads where PL100 was with the probes of my multimeter connected to ground.
                  Solder Pad "1" (the one without the three short lines coming from it): Beeps, shows "002" on multimeter.
                  Solder Pad "2" (the one with the three short lines coming from it): Doesn't beep, shows "566" on multimeter.
                  Checking continuity from the beeping solder pad to the two mosfets' solder pads, I'm getting beeps for both mosfets, so it seems like this solder pad is connected to the mosfets. So based on what you said, the two mosfets are bad? We tested them before, and it seemed like they were fine..?
                  If it helps, here's what the laptop's mainboard is looking like now:
                  • kodox
                    • Jul 2017
                    • 327
                    • Indonesia
                    #49
                    actually, there's no pin 1 or 2 on inductor
                    just said it to make easier to understand, look's like PL100 & PL701 connected directly? which pin on PL100 make the beep on multimeter? left side (from the picture) near PL701 or right side near PL101 & PL102?
                    • fireaza
                      • Sep 2018
                      • 48
                      • Japan
                      #50
                      Oh, I see!
                      I think PL100 & PL701 are connected, as I get a beep on my multimeter when I do a continuity test between the left pin (in the photo) of PL100 and PL701. Probing the right pin of PL100 doesn't get a beep though, just "500" on the multimeter.
                      The pin on the left of the photo is the one that beeps! Does this reveal anything useful?
                      • kodox
                        • Jul 2017
                        • 327
                        • Indonesia
                        #51
                        is PL701 connected directly to DC_IN socket or is there other components that had connected on same line as PL100 & PL701? Can you plug-in the dc socket then measure in continuity test on the socket where the adaptor is plugged?
                        do u have s schematic for this?
                        • fireaza
                          • Sep 2018
                          • 48
                          • Japan
                          #52
                          OK, I've plugged the AC socket back in and run a continuity test from the AC socket to PL701 and then to PL100. There is continuity to PL701 and also the left pin of PL100 (the one that beeps when grounded) but not the right pin. I don't have any schematics for this laptop unfortunately!
                          Anything useful here? Are we starting to get the cause of my problem narrowed down?
                          • kodox
                            • Jul 2017
                            • 327
                            • Indonesia
                            #53
                            i mean test in dc socket (where the adapter connected) for continuity after pluging in it to mainboard, is it beeped or not? if beeped i think the shorts in the "dc in" area, it's a main gate for 19v to enter the system, after testing it (whatever the result is) try to lift PL1 & PL3 but don't remove it, just lift one leg of PL1 & PL3 then try to connect AC Adapter and see if it's off or not, if it off remove the AC adapter immediately, if it not, you've been narrowed the shorts then
                            can you see something like LA-xxxx or DA0xxxxxx printed on the board?
                            • fireaza
                              • Sep 2018
                              • 48
                              • Japan
                              #54
                              I didn't do it right? Here's a photo of how I tested it:
                              Yeah, near the CPU it has "AAP20 LA-B753P" printed.
                              • kodox
                                • Jul 2017
                                • 327
                                • Indonesia
                                #55
                                no, it's not your fault. my mistake can't explain what i meant, but what you've doing it's okay. now, just move the black probe to ground, i hope it's beeped...
                                i'll search the schematic now, so we can had better understand what's going on and where...
                                • fireaza
                                  • Sep 2018
                                  • 48
                                  • Japan
                                  #56
                                  Yep, my multimeter beeps when I test continuity between the AC socket and ground on the motherboard!
                                  OK, let me know if you find anything!
                                  • kodox
                                    • Jul 2017
                                    • 327
                                    • Indonesia
                                    #57
                                    It's here, the schematics https://www.badcaps.net/forum/showthread.php?t=69089 post #18
                                    • fireaza
                                      • Sep 2018
                                      • 48
                                      • Japan
                                      #58
                                      Cool! But uh, I really don't know what to make of it, it might as well be in Chinese! Is there anything you can get out of it?
                                      • kodox
                                        • Jul 2017
                                        • 327
                                        • Indonesia
                                        #59
                                        look for B+ only (with bold letter) on schematics, thats where your shorts is! luckily, there's a jumper called PJPxxxx on every "B+" on this board. remove the solder bridges using wick until it's completely clean from lead but, only when it's connected to B+ only.
                                        after removing the solder bridges on one PJPxxxx, test using the continuity to ground until your multimeter not beeps anymore. if all the PJP connected to B+ removed and your multimeter still beeps, 70% your shorts caused by small smd capacitor connected to B+ line.
                                        after what you've done on measuring, the components on right side of PL100 (page 60 on schematics) is not the cause of shorts.
                                        try to test PL2 using continuity test to ground, is it beeped? if not, you can ignore it for now and back to removing solder bridges on PJPxxxx.
                                        • fireaza
                                          • Sep 2018
                                          • 48
                                          • Japan
                                          #60
                                          From what I can see, there's 2 "PJPxxxx" solder bridges in the power area of this board, PJP102 and PJP100. I've already tried to remove these solder bridges previously, but I didn't get all the solder. I'll try again with a flatter iron tip and see if I can get them cleaned. There's also a few other "PJPxxxx" solder bridges on this board, but they're far from the power area, so they're not what I need, right?
                                          Also, I thought I'd try plugging in my AC adapter to see what happens now that I have a few components removed. To my surprise, the LED on the AC adapter doesn't turn off now! Does this indicate we've possibly found where the short is? Or is this expected behavior for when the components I've removed aren't there?
                                          • roxboy1984
                                            Dell Inspiron 15 AC adapter turns off as soon as connected (MB Short)
                                            by roxboy1984
                                            Please can someone help me, im trying to find the shorted component as i have a donor board that i can swop components from.
                                            If i inject 2V/2A on DC in PU4201 gets really hot. ive changed out PU4201 from another board as well as a couple other Mosfets but PU4201 still gets crazy hot when i inject. Any ideas? im still a noob so am learning....
                                            11-20-2024, 10:59 AM
                                          • Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                            by Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                            03-15-2024, 09:37 AM
                                          • dit3
                                            HP ProBook 455 G7(DA0X9MMB8F0), fixed bad RAM power rail, laptop works, but now automatically turns on after AC is connected
                                            by dit3
                                            Hello everybody,
                                            I got HP ProBook 455 G7 which originally turned on partially(fans on 100%) and hen off after 8 seconds, with AC diode flashing orange and last flash white. This behaviour stayed for a while, but before I realised that there is power delivery issue and not BIOS problem, laptop started to automatically turn on after 2 seconds when in turned off, kept power cycling. So after I fixed shorted cap and burned ferrite bead, laptop turned on fine and booted to windows.
                                            Now, laptop can be turned off and it stays like that... unless you plug adapter again, which triggers...
                                            01-06-2024, 04:44 PM
                                          • Swell61
                                            Gigabyte X570 Aorus Pro rev1.0 diagnostics
                                            by Swell61
                                            Hello
                                            I have a Gigabyte X570 Aorus Pro rev1.0 that doesn't work. I know the motherboard is at fault because the CPU, RAM and power supply have all been tested with a known good motherboard (including after trying them in the faulty board to check it hadn't killed them).
                                            Thanks to some people on this website and elsewhere on the internet, I have a schematic and boardview for the WiFi version of this board, a schematic for the Elite version of this board (same board but cut down on features) and repair guides for other AM4 boards, one of which is for an Asus Tuf Gaming...
                                            11-07-2023, 03:32 AM
                                          • www
                                            LG L192WS-BN backlight turns off after 1 second
                                            by www
                                            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                            03-24-2024, 05:26 PM
