Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Register FAQ Calendar Today's Posts Search
Old 04-21-2018, 07:50 AM   #1
jacobtc
City & State: Aalborg
My Country: Denmark
Default Help a newbie with his first project
So, I recently acquired a Alienware 15 R1 (LA-B753P) as the guy told me it was completely dead, and I saw it as a fun project.
I have done every ordinary thing, such as resetting CMOS and leaving the RTC battery out for a while. It is completely dead, no light, nothing. The powersupply outputs 19.5V and the DC plug measures fine. I have inspected the board, and nothing seems to be obviously damaged, no burn marks, and no apparent water damage. The next step is to check for shorts, however, how would I go about doing that? I don't have a bench powersupply, so it is difficult for me to inject voltage and check with alcohol evaporation etc.
Anyone willing to give a bit of guidance?
jacobtc is offline   Reply With Quote
Old 04-21-2018, 08:13 AM   #2
caspian
City & State: Mainboard
My Country: Laptop
I'm a: Hobbyist Tech
Default Re: Help a newbie with his first project
is there any other voltages on the mainboard?
caspian is offline   Reply With Quote
Old 04-21-2018, 09:32 AM   #3
jacobtc
My Country: Denmark
What do you mean? Plugged in to the DC adaptor?
Old 04-21-2018, 11:45 AM   #4
caspian
My Country: Laptop
measure voltage on big coils and capacitors to see whether there are any voltages on the board other than the 19v.
Old 04-21-2018, 11:52 AM   #5
jacobtc
My Country: Denmark
Will do that later! Just got back from work... Thank you so much! Really hope I can get this working!
Old 04-26-2018, 07:40 AM   #6
jacobtc
My Country: Denmark
So just got done meassuring some coils and caps. Where I have not written anything is due to also being 0V.
https://i.imgur.com/40dINwh.jpg
Also, nothing felt varm to the touch.
UPDATE: I did not feel around the lower right corner, that gets really hot, around the two medium sized coils...
Old 04-26-2018, 10:00 AM   #7
jacobtc
My Country: Denmark
These get hot:
https://i.imgur.com/ao3Unj3.jpg
PL102
PL101
PC107
PC108
Old 04-27-2018, 02:15 AM   #8
dspok
City & State: Sudurpaschim
My Country: Nepal
Line Voltage: 220V
check resistance to ground on those coils. it looks like those coils are for ALW voltages, not sure though because I can't find schematics.
dspok is offline   Reply With Quote
Old 04-27-2018, 02:30 AM   #9
jacobtc
My Country: Denmark
Also, on the back, the IC called PU100, is getting burning hot, I can't keep my finger on it...
Old 04-27-2018, 02:40 AM   #10
jacobtc
My Country: Denmark
PL102 resistance to ground is 0.5 kOhm and increasing constantly, PL101 resistance to ground is 2.8 kOhm and increasing. I guess they are getting more resistant, due to getting colder over time? If I plug in power, they go down to 5ohm on PL102 and around 96ohm on PL101 when they become slightly warm.
This is the IC on the back that gets way to hot to touch: https://i.imgur.com/hJbHhtS.jpg
Old 04-27-2018, 01:37 PM   #11
jacobtc
My Country: Denmark
Anyone?
Old 04-27-2018, 01:40 PM   #12
caspian
My Country: Laptop
Now, you should read what is marked on top of the IC to identify it.
Old 04-27-2018, 02:00 PM   #13
jacobtc
My Country: Denmark
The IC has the following written on it: 3h=2b q2b
Now, I've searched for the PU100 IC, and another forum says that it is a TPS51285BRUKR...
Old 04-27-2018, 02:18 PM   #14
caspian
My Country: Laptop
it does not seem to be TPS51285BRUKR. or maybe it is. I do not know. I hope someone help identify it.
Old 04-27-2018, 02:23 PM   #15
jacobtc
My Country: Denmark
This guy identified it as TPS51285BRUKR
https://ascnb1.ru/forma1/viewtopic.php?f=31&t=130165
Old 04-27-2018, 02:44 PM   #16
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
data sheet
vinceroger69 is online now   Reply With Quote
Old 04-27-2018, 03:17 PM   #17
jacobtc
My Country: Denmark
Originally Posted by vinceroger69 View Post
data sheet
The package looks different to what is in the data sheet, this one has five pins on four sides, the one on the data sheet has only pins on two sides.
Old 04-27-2018, 08:41 PM   #18
Johndill
City & State: NSW
My Country: Australia
Is this the correct schematics for your board?
PU100 page 60.
File Type: pdf sualaptop365.edu.vn_15or17 LA-B753P.pdf (2.12 MB, 144 views)
Johndill is offline   Reply With Quote
Old 04-27-2018, 11:51 PM   #19
JaroTech
City & State: Montréal, QC
My Country: Canada
Hi, the code '3H =' comes from Richtek, the chip is a RT6585B, it is compatible with the chip TPS51285B.
JaroTech is online now   Reply With Quote
Old 04-28-2018, 02:51 AM   #20
jacobtc
My Country: Denmark
PU100 page 60.
Looks like it, thanks!
Badcaps.net Technical Forums © 2003 - 2022
