Alienware m17x r4 snowy screen..
  • appie1206
    • Oct 2016
    • 127
    • netherlands
    Re: Alienware m17x r4 snowy screen..
    Originally posted by SMDFlea
    Thats the suggestion at the last post in that forum,although he never posted again to say if replacing those IC`s fixed the problem or not . You know its not the cable or screen.
    Edit: http://*******/viewtopic.php?f=41&t=38172&p=456225
    1 million procent its not the cable, screen,videocard,processor....all of those i replaced and i still had the same problem. I ordered today the chip from china so i have too wait at least 3weeks i think
    • appie1206
      • Oct 2016
      • 127
      • netherlands
      If i desolder the component from a other laptop wil it work you think?
        • 21948
        If you have a donor board ,yes its worth a try .
        • appie1206
          • Oct 2016
          • 127
          • netherlands
          Its from a acer motherboard is complete dead... its not a alienware.
            • 21948
            If the IC part number is the same its ok .
            • MJ-meo-dmt
              • May 2016
              • 186
              • South Africa
              #26
              What is the code on that board? Alienware is dell pretty much. LA-xxxx?
              This sounds like the LVDS translator/Controller/converter IC... not sure on the exact desc or name.... Do you have a Schematic?
              EDIT: I think this schematic is the right one, attached below.
              EDIT2: #_# ah I see that is indeed the chip(page28) mentioned from the other forum... anyways if you have another like that swap it should work just fine.
              while alive { live(toFullest=true) }
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                #27
                I had a similar problem on an Asus laptop. But the customer did not give me time to fix it properly. Finally, I discovered that if uninstall Both the ATI and Intel Graphics drivers, the snow will disappears. So the customer was glad of this quick fix.
                there is a Graphics option in Bios. change it from switchable to something else. It may be fixed this way.
                Then, you can try replacing the LVDS multiplexer IC. It can be desoldered from any mainboard. I hope it is not faulty.
                • appie1206
                  • Oct 2016
                  • 127
                  • netherlands
                  #28
                  Its fixxedddd it was indeed the chip😁😁..... there where 2 of those chips. I replaced the one near the connector.
                  Thank you very much😁
                  • appie1206
                    • Oct 2016
                    • 127
                    • netherlands
                    #29
                    It was this ic PI3LVD1012BE its running fine now
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • kain0007
                      Alienware X15R2 P111F black screen after updating windows.
                      by kain0007
                      Hi Masters.
                      I have an Alienware x15R2 laptop that went black after updating Windows.
                      Could someone help me repair my bin?
                      Alienware X15R2
                      ST: 1CJY6M3
                      Thank you very much for your support....
                      10-09-2025, 02:20 PM
                    • jagiro84
                      Alienware x15 r2 black screen
                      by jagiro84
                      Hi there I hope someone can help me with fixing this issiue
                      ​​​​​​Symptoms
                      My Alienware x15 r2 stopped working, which is around 2years old.
                      ​​​​​​ power light and keyboard turns on, power lights give 2red and 3 blue lights,
                      screen stays black
                      From dell error codes it says this is error
                      2,3 No memory or Random-Access Memory (RAM) detected
                      after disassembling and removing battery removing any electricity left with power button on without psu connected,...
                      11-25-2023, 03:44 AM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
