macbook pro retina 2014 820-3476 missing pp5v_s0
  • ub6ib969
    • Jul 2010
    • 201
    when plugged in no fan spin however green to amber light. I am missing pp5v_s0, any help would be appreciated. The unit was not a liquid spill.
    thanks
  • salopian
    Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
    by salopian
    Hello. I would need some advice please.
    My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
    He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
    I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
    I have already replaced the logic board with another...
    02-27-2021, 07:30 AM
  • jasonr2000
    MacBook Pro 2014 Retina Power Cycling
    by jasonr2000
    hi guys I have the above mentioned MacBook Pro 2014 Retina 13"
    and its power cycling no matter what I do.
    it powers on chime turns off does the same over and over.
    I've checked voltages and they are going up and down the 5v one gets there then falls to 0v 3v3 also does the same thing goes up to 3v then falls off.
    any ideas where I can check next ?
    I did notice a slight bit of corrosion in the are highlighted in the image.
    none of the water indicators have changed colour so I'm not sure how it got wet there...
    01-11-2024, 09:41 AM
  • ugamazing
    820-02020 PPBUS_AON missing
    by ugamazing
    Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
    Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
    02-05-2025, 04:21 PM
  • jpreza
    Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
    by jpreza
    I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
    Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
    It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
    Looking at the card, it appears to be missing the following:
    1x 1.0uH inductor - orange square
    2x...
    11-01-2024, 10:54 PM
  • gurj1979
    Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
    by gurj1979
    Hey guys.
    Need help with this one.
    Fan not spinning due to missing PWN Fan signal.
    Also 5 seconds from powering up it freezes, unless in BIOS.
    But as soon as Windows starts to load, it will freeze.
    CPU is COLD / Room temp when it freezes.
    I've replaced the CPU, same problem.
    Replaced SIO/KBC IT8987e and reprogrammed - same problem.
    Replaced fan - same problem.
    Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
    Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
    08-19-2024, 05:22 PM
