Question for the highly technical driver/hardware
  • bjhawfam
    • 144
    I was working on this board that had liquid damage. I was able to replace the mosfets (pq44) the caps (pc192, pc193, pc194, pc195, pc190) and the resistor pr222, NOW I have power to the board.. There was also damage to the LCD connector on the motherboard,, I was able to use solder and fix the issue.. Now, I'm able to load Windows and use the laptop without any issues, EXCEPT, WHEN I LOAD THE VIDEO DRIVER... Interestingly, the laptop will work with the intel driver loaded anywhere from 40 seconds up to several minutes until it completely freezes and it has to be manually shut down.. If I uninstall the driver I can use the laptop all day without fail..
    I originally thought it was solely a driver issue. I tried multiple drivers from the newest to older drivers and the result is the same (yes bios has been updated)..
    My question is, if it's hardware related what would be the signal change if any at the LCD connector on the motherboard? More specifically ,, would the installed driver vs no driver loaded have any effect on the LCD data lines that would be noticed at the LCD connector?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Re: Question for the highly technical driver/hardware
    gpu ic issue. rework or replace
    • osrex
      LED DRIVER KEEPS DYING
      by osrex
      Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
      i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
      i have no datasheet at all for the LED lights, all i have is its length.
      long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
      as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
      05-05-2025, 03:36 PM
    • howardc64
      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
      by howardc64
      Problem
      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
      Model & Board Pics
      Conflicting Spec
      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
      https://www.shopjimmy.com/vizio-gj-2k1...
      10-10-2024, 01:16 PM
    • charif
      Audio Driver for Thomson P14C4BK128
      by charif
      Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
      I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
      The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
      Here are the details:
      • Model: Thomson P14C4BK128
      • Operating System: Windows 10 64-bit
      If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
      Thanks in advance for your help!
      04-30-2025, 05:41 PM
    • bohaboha
      how to install gl usb2.0 uvc camera device driver on windows 10
      by bohaboha
      Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
      but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
      any help?
      01-26-2025, 08:33 PM
    • Daveleone
      UN55D6900 BN44-00428B partial led driver circuit failure
      by Daveleone
      Hello TV experts! I have a UN55D6900. The successfully TV turns on, and the backlights light up, and I get a picture, but there is a section that is dim. I took it apart and 1 out of 4 segments of backlight LEDs are not lighting on both sides of the TV (in other words, the same segment is out on both LED strips).
      I tested the LED strips with my LED tester and all of the LEDs light properly, so I believe the problem is with the PSU/LED driver board (BN44-00428B). The voltages at CNM810 (between PSU and main board) look ok to me. The voltages at CNL801A and CNL801B look off for one...
      07-23-2021, 06:31 PM
