Lenovo T510 Fan error
  • basskilla
    • Mar 2014
    • 18
    • Hungary
    Hi there!
    I have a Lenovo T510 with a Fan error message on the startup.
    I have found this forum,It say fuse F13 is the problem,near the fan :
    https://forums.lenovo.com/t5/ThinkPa...r/td-p/3548532
    I measured it,and that was wrong,and I replaced it.
    Now the fan is spinning in the start,but after a few sec, it is stopped,and the same fan error message again.
    I cleaned up the fan,and I replaced it with a temporary test fan,same result.
    I have the schematic,what I attached,but I can't figure out what is the problem.
    If You have some idea please help to me!
    Thank You!
    Best wishes!
    • 20952
    Re: Lenovo T510 Fan error
    Try to resolder the 6 pins of U45 , use plenty of flux.
    • basskilla
      • Mar 2014
      • 18
      • Hungary
      Thank You,I tried it but nothing changed.
      I have a donor motherboard with the same U45 chip.
      If I swap those chips,can that solve this fan error problem?
        • 20952
        Try it
        • R_J
          • 9535
          Do you have the FAN_ON signal? I assume it is a pwm signal to drive the fan at different speeds
            • 20952
            FAN_ON into Q21
            • sicilianul
              • Jul 2014
              • 70
              • Romania
              Hello. Same problem here. I have 5v FAN_ON on q21, VDD_FAN and FAN_FRQ all for 1 sec. Any ideas ?
              • sicilianul
                • Jul 2014
                • 70
                • Romania
                LE: My problem was Q20. Removed. Made a short between B + C. Replaced the FAN. Everything is fine now.
                • m.ksy
                  • Jun 2021
                  • UA
                  thanks!
                  also helped in my case with w510
                  • fester
                    • May 2017
                    • 158
                    • Slovakia
                    The same problem ,shorting B anc C of Q20 helped. This new ordered fan have probably another output section for rpm sensing. thanks
                    • Askic
                      • Sep 2018
                      • 187
                      • BIH
                      Wait the sec. If you remove Q20 and short B and C, then, this part of t ecircuit will become a voltage divider. That means that FAN speed will become constant. There will be no way to control the speed. Maybe this will be sufficient for the most time, but overheating is possible.
                      • MIGUELIX
                        • Apr 2012
                        • italy
                        Hi , i have same problem , a seller ask me , those boards , check the fan , but i read only a peak of volt and after immediately "Fan error " , i don't think are the fan , anyone have tried to put another fan before working around the Q20 transistor ?? Thanks for your help . Miguelix
                        • mon2
                          • Dec 2019
                          • 14219
                          See attached.
                          Measure the voltage output of the 3v3 TACH feedback @ Q21. Do not bypass this transistor else you risk to damage other parts on your logic board.
                          Without the use of Q21, the voltage output from the FAN is not limited - it can swing to a dangerous value and kill the digital feedback pins used to monitor the FAN operation.
                          Post the voltage at each leg of the circuit to review.
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3597
                            • slovakia
                            what is signal TACH from FAN? pulse or analog? im to lazy to check with scope if somebody know it
                            • mon2
                              • Dec 2019
                              • 14219
                              See attached. (borrowed without permission from another website)
                              The output is apparently open-drain so there is a low signal but no HIGH signal - instead, the transistor is OPEN and the internal pull-up will define the 'soft high voltage'.
                              On this note, only 5v is being fed into the fan connector so very likely the pulse stream output swing (hall effect switch will trigger upon each revolution of the fan) will be 0 to 5v which is too high for digital logic to accept without damage.
                              Respectively, Q21 will perform this level shifting to the 0 to 3v safe levels.
                              • Maxpower3
                                Brand name and Model Type for Lenovo error 2202 product name is invalid
                                by Maxpower3
                                Info for error 2202 LenovoThinkPad models and type
                                Extract from ThinkPad Maintenance Utilities Configuration File
                                plnsrv.ini Version 1.01
                                Some information that may be useful
                                There must also be missing models, add them to the list if you know of any.
                                Code:
                                brand name
                                20B1=ThinkPad Edge E445
                                20B2=ThinkPad Edge E545
                                20BC=ThinkPad Edge E145
                                20BM=ThinkPad X140e
                                20BL=ThinkPad X140e
                                20A3=ThinkPad X230s
                                20AH=ThinkPad X230s
                                20AK=ThinkPad X240s
                                20AJ=ThinkPad X240s
                                02-21-2024, 10:27 AM
                              • NecroFlex
                                Need fan error removed from BIOS Lenovo S200 10HQ
                                by NecroFlex
                                Hello, i have 2 of the same machines, the 1st one is dead, it is plagued by this issue (same board model):
                                https://www.badcaps.net/forum/troubl...=4#post1606399
                                So it's not worth saving (flashes lenovo logo for a sec, then reboots to a black screen), the 2nd one only has the fan error that stops it from booting unless you press F1. I'd need the error removed so that the system...
                                10-17-2024, 06:44 AM
                              • Sus256
                                HISENSE 65E7KQ PRO - no boot
                                by Sus256
                                Hi all!
                                HISENSE 65E7KQ PRO
                                RSAG7.820.13512 - chassis
                                MT9618BAATAB - cpu
                                RSAG7.820.12059 - power
                                HD650Y3U77 - panel
                                KLM8G1GETF - emmc
                                The TV does not turn on, the standby indicator is on. All voltages are present.
                                Emms is dead. Not readable, not detected.
                                Replaced emmc.
                                But with another dump there is no launch
                                Terminal log
                                UART
                                AC_ON
                                RPMB key is not yet programmed
                                HASH1_VERSION=0x00000000 64bit
                                E-B
                                FDE enabled
                                layout pattern onebin by SAR7,0...
                                06-01-2025, 02:11 AM
                              • Good2Know
                                Lenovo T590 20N4 noscreen error 0288
                                by Good2Know
                                Hi.
                                I bought a defect laptop for training porpus (maiboard troubleshooting /repair etc).
                                As advertised by the seller it turns on, fan spin but no display.
                                First thing i did was disconnect anything (ribbon cables) that could eventually cause the display not to work.
                                Still no display, not even via hdmi.
                                But after removing display cable off the mainboard it worked "perfectly" fine via hdmi.
                                So i installed a spare ssd and installed win10 without any issues.
                                With all the drivers installed via win update and lenovo vantage i went back to bios...
                                03-16-2024, 04:31 PM
                              • przemek_79
                                Lenovo L15 G1 error 1802
                                by przemek_79
                                Hello everyone, After installing the second m2 SSD drive in place of the GSM card, I have error 1802. There may be a way to bypass this error.
                                Here is the Info of the Laptop
                                Lenovo L15 G1
                                S/N PF1SK5ST
                                Ryzen 5 Pro 4650u processor​
                                07-19-2024, 06:39 AM
