Mainboard consum 0,25AMP/ wont start , Please help
  • Richi_el
    • Nov 2013
    • 95
    • Koln
    Hello, can somebody help me with this Device? ( its like a Notebook)
    There are no schematics for this board avalabile, but ive tested some parts to change, but no reaction.
    Normaly the device has an Autostart mechanisim (power on when 12V plug in).
    I checked the board with laboratory power supply but i have allways the same issue the device wont start and consum not more then 0,25amps.
    Normally when the device start it should consum about 1,4 – 1,6 Amps
    The 12V, 3,3V and 1,6V are present on the board.
    The device has a LED on front wich is flashing permanently.(no screen)
    I tried t change several parts wich u can see in the PICs but no success, can anybody give me a note ?
    NOTE :
    On The Backside of the board is an NVIDIA T20MGS-SH-A4 ( I think Graphic , North / South / CPU all in ONE ) BGA wich i changed to.
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Mainboard consum 0,25AMP/ wont start , Please help
    Because there is no schematics, repairing this board may be too difficult and takes a full month or more. If you have time and if you are determined to do this repair, start by the first step: Find all the square-shape coils and report voltage on them. then, focus on ones that have no voltage and try finding the reason.
    then, you can do some more steps.
      But can you manually start it up?
      • Richi_el
        • Nov 2013
        • 95
        • Koln
        @caspian many thanks for your help,
        today i have measured all coils, and i see that the coil by V-IN has no power (i think its in short) see in the pics. When i disconnect the spoil i have 11,9V there but even if i connect the 12V are not present.
        The other coils on PCB has power and work fine.
        I tried to dissconnect other parts (like marked f parts ) to separate the circle but its still in short.
        Also i have seen that the R422 Resistor should give 1,6 but when the Parts are connected i have only 0,6
        Can somebody tell me what is the L10 ?? is it only a brigde ?
        I also uploaded the Backside pic so (but i didnt see so much things in the back)
        Can somebody help me to find the issue ?
        @ BUDM no the board has no manually power on (starting porcess will beginn when connect vin)
        Many thnx for helpers
        • Richi_el
          • Nov 2013
          • 95
          • Koln
          Hello here an Update to my case.
          today i concentrate my self to the near of the CPU because i think that the porblem mayee is on CPU V-CORE. (see on pic the measuring points)
          ALL COILS are good.
          The CPu is getting hot, but not so much and the device consum not more then 0,35 Amps , the rams are getting normal hot. (are they starting?)
          i measured 1,5V on Crystal in the near of CPU and 3,2 V by caps and some resistors, but on right side of CPU are Resistors with no power, could be normal ? (see on pic)
          Can somebody tell me wich part sends the reset signal to North South bridge ?
          I have seen this video and try to find the fault with the consumption of board , is it possible ?
          https://youtu.be/ASqHvtNks9E
          Can it be that the problem is in the sequence between secorndary power and to V-Core to CPU and is this method possible to find the issue?
          Or can it be that is a bios issue ? (but bios should start by 0,85 AMPS consumption after north South brigde start like demonstrated in the video)
          and can somebody tell me wich type of Flash 41A18 JWA07 is on the last pic and wich programmer can read /write is the best for it.
          Many thanks for your support
            • 20311
            Micron JWA07
            https://www.elnec.com/en/device/Micr...5BWFBGA153%5D/
            https://www.aliexpress.com/item/EMMC...270054778.html
            These are adapters for the popular RT809H programmer
            https://www.aliexpress.com/item/Free...ceBeautifyAB=0
            • Richi_el
              • Nov 2013
              • 95
              • Koln
              Hello, many thanks for your reply and for the programmer
              do you know where can i order a blank Emmc of that type ``??
              • Stevie2001
                • Apr 2018
                • 183
                • irland
                Loool Q49 looks blown
                Look at Q49 blown
                Look at Q49 blown
                Look at Q49 blown
                Look at Q49 blown
                Change Q49
                Change Q48 or test.
                You need to work more on your solder skills i can se bad work also near r320 your solder may have short clean it
                • alrep
                  • Sep 2017
                  • 8
                  • Russia
                  Is this a Technogym treadmill?
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
                  • jb_Bak
                    by jb_Bak
                    CN6401
                    Pin 01 NC
                    Pin 02 NC
                    Pin 03 "BL_ON": 0V
                    Pin 04 "N/C"
                    Pin 05 "STBY 3.3V": 3.5V
                    Pin 06 "GND": N/C
                    Pin 07 "AC_OFF"...
                    09-27-2021, 04:52 PM
                  • canadaboy25
                    Panasonic TC-P54VT25 No image. A or D board?
                    by canadaboy25
                    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                    The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                    01-17-2021, 01:06 AM
