G74A motherboard shuts down
  • bjhawfam
    • Dec 2014
    • 144
    Re: G74A motherboard shuts down
    Now when I go back and check voltage I see that PLTRST# is not present when checking against pin 44 at the mini card location will continue to dig around..
    • piernov
      • Jan 2016
      • 4435
      • France
      If the PLTRST# signal is not present, the BIOS will not start to run.
      Check for CPU VCore first.
      • bjhawfam
        • Dec 2014
        • 144
        I did check and I don't have voltage to CPU...
        • bjhawfam
          • Dec 2014
          • 144
          So no cpu_vcore and sys_pwrok comes and goes ( Sometimes it gets power and sometimes it don't)...
          • bjhawfam
            • Dec 2014
            • 144
            Disregard on the sys_pwr (fixed)..
            • bjhawfam
              • Dec 2014
              • 144
              Just wanted to give an update for those who may run into the same issue.. I BELIEVE there's possibly a short to ground on the vcc_rail.. I'LL Spend more time later on it.. ...(EDIT) After checking there is a short to ground..
              • Thedoc298
                • Apr 2018
                • 6
                I do have an update on this matter...
                The new ITE8987E chips arrived and I replaced it today... With a new bios in place and after the ITE was soldered on I powered the laptop on and found it in the exact state as the original post.. With a new eight pin bios chip and a different g74a bios downloaded onto it,, and with a new ITE8987E chip (blank) the laptop still powers on for a second and than back off... Interestingly, I can tell you that in fact the ite8987e is programmed automatically.. With the new chip in place I created a blank 128mb file and I wrote it to the ITE via the svod programer, however, the blank file was over written automatically when powered back on... So now, either I have two bad bios (8 pin ) files or the problem lies elsewhere.
                Had the same thing happning to GA-970a-ds3p. In the end it was the cpu. Had an older cpu with same footprint, dropped it in and good to go.
                • bjhawfam
                  • Dec 2014
                  • 144
                  Good to hear you fixed yours.... If this 8th Gen CPU is shot, The one thing I don't do is replace CPU's by de-soldering them from the board... Miss the older CPU's that you could remove and replace...
                  When I get bored I'll try and locate the short to ground.. So far I removed a few SMD's and the short still remains.. I just hope the previous owner didn't try heating the CPU....
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4952
                    • New Zealand
                    #29
                    Is it a dead short or some few ohms? CPU itself will show low ohms even when OK, but not dead short.
                    -David VanHorn
                    • bjhawfam
                      • Dec 2014
                      • 144
                      Not just a few ohms. I'll try and isolate or narrow it down. Hopefully there will be no other issues. Thanks, I'll check back when I have more.
                      • bjhawfam
                        • Dec 2014
                        • 144
                        Turns out,,, it is with out a doubt a short to ground somewhere in that circuit, finding it will be a headache. Not sure if I'll spend much more time as all the components are showing the same failure due to the short.. I cant see any visual signs that would help single out a short... Thanks to all that helped and shared their ideas....
                        • latinphoenix7
                          • Jun 2011
                          • 10
                          #32
                          Sorry for that, but I certainly think CPU is bad/damaged. I know It's hard to detect the problem. However, you should notice some OVERheat on it in a very short time (when the power button is pushed
                          ). Put a drop of isopropyl alcohol on die and you'll see...
                          • alas3376
                            • Nov 2011
                            • 382
                            • BENIN
                            #33
                            need boardview of this and EC dump , plz
                            • KvnTM
                              • May 2018
                              • 434
                              Post your request in BIOS/Schematic Requests and don't hijack an old thread.
                              • 12gitari
                                • May 2021
                                • kenya
                                #35
                                i have G74a which is showing only the charger led and nothing else... most coils have no voltage what could be the most suspected problem?
                                • sarry86
                                  • Jun 2021
                                  • 90
                                  • Tanzania
                                  #36
                                  Click image for larger version  Name:	PXL_20240124_195257087.jpg Views:	0 Size:	7.13 MB ID:	3203582 MineMine too has same problem, all those caps and coils are shorted to ground and I have tried to remove mosfet and caps and testing them to no available, did you find what shorted the vcc core to ground? Or is it the cpu that is gone? 😭
                                  NB: I have 3 volts, 5 volts and 1.01volts
                                  Last edited by Vesko356; 01-24-2024, 11:32 AM. Reason: Image scaled, duplicated image removed.
                                  • sarry86
                                    • Jun 2021
                                    • 90
                                    • Tanzania
                                    #37
                                    I have an update to the issue, I have come to realize that there's no 3 voltage on pin 11 of the ITE8987E ic, the 3V_ALW is there but doesn't reach the SIO ic
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      #38
                                      It may not be a short. Cpu Vcore area and VCCGT area will show low resistance for onboaard cpu. What is the exact resistance to GND??(Meter should be in ohms mode and at lowest scale)
                                      • sarry86
                                        • Jun 2021
                                        • 90
                                        • Tanzania
                                        #39
                                        Thanks for responding, 16 ohms around smd caps and 4~5ohms around coils
                                        • mcplslg123
                                          • Jun 2015
                                          • 7262
                                          • india
                                          #40
                                          Thats not a short-its normal.
