NM-A281 SY8206BQNC 3,3V output issue
  • rookieme
    • Oct 2014
    • 396
    • Greece
    I have the NM-A281 with fried the KBC.
    I also noticed that the SY8206BQNC [pu401] that provides the 3,3 V gives 3,83V at +3VLP and at +3VALW.
    That must be a good reason why KBC was fried.
    I removed the KBC and measured the parts that regulate the output in my opinion - the PC411, PR407, PR444 and the PC403 are ok.
    Also I replaced the SY8206BQNC but i get the same output that is too high.
    I placed a new KBC and also noticed that U13 burns hot I guess by the efford to regulate down as I get 3,07 & 4,94 at the ouput [no short at output].
    Any suggetions what goes wrong and I get too high voltage instead of 3,3V?
  • mielta
    • Apr 2015
    • 368
    Re: NM-A281 SY8206BQNC 3,3V output issue
    Hi
    Wich voltage you have on PU401 En1+2
    when you cut PJ402 is the voltage always 3,8V
    • rookieme
      • Oct 2014
      • 396
      • Greece
      PU401 pin1 has 3,82V and pin2 0V
      nice, by cutting PJ402 I get 3,34V at +3VALW_P and at +3VLP
      also PU401 pin1 now is 3,33V and pin2 3,76V.
      I'm guessing you have faced that before?
      U13 still runs hot
      • mielta
        • Apr 2015
        • 368
        Check pu402 voltage +5valw
        • mielta
          • Apr 2015
          • 368
          i think it is problem +5valw or u13 is defect
          • rookieme
            • Oct 2014
            • 396
            • Greece
            +5valw is 5,1 V and seems fine
            ok U13 is faulty, without it and with PJ402 closed I get 3,3V
            now long time waiting for a replacement
            thank you for your time!
            • mielta
              • Apr 2015
              • 368
              with pleasure
              • islammostafa.me19
                • Jul 2017
                • 39
                • egypt
                thanks
                • imranromi
                  • Jan 2015
                  • 1288
                  • Pakistan
                  I face same problem like 10 time problem found sound ic short to gnd..
                  • FrancescoV
                    Onkyo HT-R390 no sound output, video output ok
                    by FrancescoV
                    Good morning everyone,
                    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                    The firmware reported is the following:
                    M:1.00/11107BLP
                    D:?.??/????????
                    O:1.00/11107AL
                    The DSP firmware given the question marks seems corrupt.
                    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                    05-11-2025, 02:59 AM
                    NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                    I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                    I bought this from an eBay seller but unfortunately they only had one
                    I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                    I bought three of from them to also make battery packs with this output power limit in mind
                    I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                    04-23-2025, 05:50 AM
                  • rounin
                    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                    by rounin
                    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                    🛠 Original Issue
                    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                    04-19-2025, 01:18 AM
                  • CoppellTVRepair
                    Troubleshooting PFC with SPC1012T not raising output
                    by CoppellTVRepair
                    It has been a long while since I posted here to ask anything....hope you can help.
                    I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                    I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                    03-09-2025, 10:38 PM
                  • flibidy
                    Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                    by flibidy
                    I have here a Magnum IA.100 which belongs to my parents.
                    The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                    Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                    What Ive done........
                    01-01-2025, 01:26 PM
