LA-8241P DELL, short circuit ?
  • warsztat
    • Feb 2017
    • 189
    • Polska
    Hello, my problem it possible short circuit in the region GPU.
    I have a diagram but i do not have board view.
    This short circuit occurs at everyone RAM GPU, i suspect there is power but maybe i'm wrong but occurs there 0 ohms. (sorry my bad english)
    Foto :
  • khaahk
    • Dec 2013
    • 759
    • Estonia
    Re: LA-8241P DELL, short circuit ?
    If 0 ohms, use lab PSU to find short.
    • warsztat
      • Feb 2017
      • 189
      • Polska
      Thank you for your answer. It will be a last resort. I am looking for info mark capacitor on the schematic.
      • BlueMidnight
        • Jan 2015
        • 489
        Ohm's Law: Voltage = Current x Resistance
        For some components (e.g. the CPU and GPU), their power rails will show a very small (less than 1 ohm) resistance. This is because they operate on a very low voltage and draw a large current. Small voltage / Big current = Small resistance.
        You did not say exactly what the symptoms are. But you might want to plug in the board and measure voltages on the power rails instead.
        • warsztat
          • Feb 2017
          • 189
          • Polska
          GPU removed. Still 0 ohm. No short circuits on the GPU / RAM power converter.
          I need board view or info.
          • khaahk
            • Dec 2013
            • 759
            • Estonia
            Why is using lab psu to find short your last resort? If no boardview available then it should be the next move.
            If the capacitor is on the memory power line then short should also be on buck converter chip output and parallel to a lot of other capacitors. What help do you get from boardview in this situation?
            • warsztat
              • Feb 2017
              • 189
              • Polska
              My worked out procedure. Current I would like to give from the power side and I do not know if there is a key on this line and is this line.
              • warsztat
                • Feb 2017
                • 189
                • Polska
                I found some time for this case. I find short circuit, it was not a broken capacitor. The short circuit was under VRAM, melted balls bga. I measured measurement points on connections to the GPU that was weird, because my english is bad I attach the photo.
                Lab PSU to find short did not help in this case.
                Someone warm up GPU moved UV24. I'm another person trying to fix.
                Currently all system on site, board takes ~1-1,2 Amp, the system speaker makes regular short squeals not screen on lcd.
                I do not know the error code, GPU broken ?
                • coolwiz computers
                  • Oct 2016
                  • 4
                  • Nigeria
                  if you have another GPU YOU CAN CHANGE IT OR YOU RECHECK MAYBE A POWER MOSFET IS CAUSING THE SHORT
                  • warsztat
                    • Feb 2017
                    • 189
                    • Polska
                    Power on VRAM 1,5V , power mosfet ok. I was programming bios, bios from dell 5520 = 5 beep, bios another one dell vostro 3560 (this laptop) = 1 beep per 2-3sek. I do not have others bios this motherboard. Maybe change GPU.
                    • spleenharvester
                      • Mar 2010
                      • 902
                      According to internet sources you can convert these boards from dis to UMA simply by removing PL800. Is it maybe worth testing without PL800 if you are unsure whether it is a GPU problem?
                      It's also worth noting these boards will not POST unless there is an LVDS/screen connection present, even to an external display.
                      Also 5 beeps can be CMOS battery issue
                      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                      • warsztat
                        • Feb 2017
                        • 189
                        • Polska
                        Battery cmos ok, i think bios wrong this board (5520 > 3560), no screen on external monitor unless LVDS connector, beep still is it.
                        First advice (removing PL800) not known to me, maybe i try how I find time. Thank You.
                        • warsztat
                          • Feb 2017
                          • 189
                          • Polska
                          The laptop owner resigned from the repair, thank's all.
                          • Geeker007
                            9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                            by Geeker007
                            Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                            I am new to electronics repair, so my queries could be naive but I am ready to learn.
                            So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                            01-28-2025, 03:31 PM
                          • playit
                            laptop 19v short circuit dell vostro 1400 motherboard ,need help in repair .
                            by playit
                            the comon problem they say , the charger will shut off power once plugged to laptop , i dont have battery, its long gone ago , i use it for backup with adapter and vga port to external monitor(yes no screen lcd) in case my desktop needs fix . one thing for sure i could say the clr resistor - r010 beeps ,short at both sides , the checked all the coils , the 3 coils together gives all of them beeps short along with their respective capacitors . i dont have voltage ampere injection dc machine as in videos i have seen they see where its getting hot and they remove the short and replace components...
                            02-25-2025, 08:15 AM
                          • aaronkatrini
                            Help me find the short circuit on this WORKING Nvidia GTX1650
                            by aaronkatrini
                            Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                            Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                            04-18-2024, 03:15 PM
                          • fab13
                            Nintendo Switch lite charging chip heats up and does not short circuit
                            by fab13
                            Hello everyone
                            Small technical problem on a Nintendo Switch lite
                            Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
                            After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
                            When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
                            Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
                            09-16-2023, 04:59 AM
                          • Tarot Superstars
                            Short Circuit tester
                            by Tarot Superstars
                            Hello.
                            I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                            The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                            Link
                            The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                            https://www.youtube.com/watch?v=0eixDdCpiO4
                            My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                            09-25-2023, 09:11 AM
