Good programmer
  • Pascal Komlassan
    • Jan 2017
    • 809
    • TOGO
    Good programmer
    looking for a good programmer that can flash *Laptop* ; *Tv* ; *Car* ; *Bios*
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Good programmer
    A single programmer can not be found to do them all properly. You need at least 2 powerful programmers. If you buy cheap programmers, you need 3 programmers. All the programmers which you buy, should be able to do programming for the following interfaces:
    - SPI
    - Jtag
    - KBC
    - TV Bios interface (that I do not know what it is.)
    - ECU Bios interface (that I do not know what it is.)
    A very good programmer is TNM5000 which is expensive. I do not know whether it is available in your country or not.
    You can use a combination of EZP2010 and SVOD which are good and powerful.
    • dspok
      • Jan 2014
      • 553
      • Nepal
      Re: Good programmer
      I don't like SVOD, becoz it needs extra $10 each to activate ITE and novuton.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        Re: Good programmer
        i do my work with CH341A and hand made Willem 3.1 (i also have ver 5.0e for some new chips) and some hand made adaprers
        https://www.ebay.com/itm/CH341A-STC-...sAAOSwgN5ZpSEe
        https://www.ebay.com/itm/PCB5-0E-Wil...oAAOSwupladCDQ
        cannto do sio chips with those
        Im Back... sort of...
        • Pascal Komlassan
          • Jan 2017
          • 809
          • TOGO
          Re: Good programmer
          - SPI
          - Jtag
          - KBC
          Thank you brother.
          1- I have the SVOD but I can not master its full use (I can not flash the KBC - ITE - ENE and other) I still have some trouble using.
          2- I also have the TL866CS which works well for the moment but only flash bios. not the KBC ITE ENE NUVOTON and others
          • Pascal Komlassan
            • Jan 2017
            • 809
            • TOGO
            Re: Good programmer
            okay OK OK so that's why I do not work yet.because I install it on my pc but every time I want to flash a KBC or ITE its fact lost
            • Pascal Komlassan
              • Jan 2017
              • 809
              • TOGO
              Re: Good programmer
              You are strong my brother
              You are a venerated master of the domain
              I salute your efforts and all the help you do for the evolution of everyone
              • dicky96
                CH341 Programmer - any good for 1.8V?
                by dicky96
                Hi guys
                I have a TL866 CS Eprom programmer and up until now it did everything I needed to do
                However for the first time I have come across a 1.8V Eprom and my programmer will not do 1.8V
                I need to program a 25Q64FWTG
                I could splash the cash and buy a V11.71 TL866II. These come with various attachments and the kit including a 1.8V adapter is either €62 with 12 adapters or €68 with 1 7adapters. I also have the option to buy just the programmer for €46.70, if I could get the 1.8V adapter separately and use the other eprom adapters from...
                01-31-2022, 06:14 AM
                by SMDFlea
                Bad...
                09-02-2021, 04:40 PM
              • Teeheeze
                RT809H Programmer Firmware Corrupted
                by Teeheeze
                This is a shot in the dark, but I was just using my RT809H programmer and it got stuck in a certain state so I power cycled it. Now, the device LED just flashes quickly and does not connect to the software. I've tried to update the BIOS of it and it fails. I went so far as to remove the ROM from the programmer itself but it's some weird chip (I believe ATMEL, but I can't find any datasheet on it) so I've been unable to read the BIN from it w/ my other programmer. Chip has ATMLHC4C56BM CN written on it (I think). I'll upload an image. I have the programmer's BIN ready to program it manually. Anyone...
                02-13-2025, 04:51 PM
              • irepair559
                Ps4 1215a hdmi diode readings good everything good but no pic??
                by irepair559
                PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
                01-05-2023, 12:32 AM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
