sony pcg-3h1m No start
  • NConstantinou
    • May 2017
    • 334
    • Cyprus
    i have a sony pcg-3h1m.
    when i plug adaptor red light comes on power. when i switch on fan spins and
    stops at once and power red light flashes and then power light is off.
    i checked capacitors and L and is shown that i have short on VDD_CORE.
    does anyone has any idea or i have a short on BGA
  • NConstantinou
    • May 2017
    • 334
    • Cyprus
    Re: sony pcg-3h1m No start
    [QUOTE=NConstantinou;799906]i have a sony pcg-3h1m.
    • caspian
      • Oct 2015
      • 1589
      • Laptop
      If you did not do any BGA rework on that BGA chip, that chip is probably not the source of the short.
      • Ihandyrepair
        sony 55X850D black screen no front white or red led light.
        by Ihandyrepair
        Hi guys
        strange one
        I have a dead Sony 55X850D
        when plug in, black screen, no front white or red LED, no back light no screen
        Voltages I get
        3.3v LD/power and main board
        reg 12V
        reg 19V
        3.3v on power on pin
        no Tcon on
        no tcon 12v
        no BL_on
        I do get BL_ERR 2.0v
        I tried to bypass it by ground it but still get same symptom
        I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
        or is possible the chip next to...
        08-07-2024, 04:58 AM
      • YasaCh
        Sony kdl 40p5500 red light keeps blinking 3 times
        by YasaCh
        Hello...
        my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
        i opened the back cover no sign of damage on the powery suply or motherboard
        when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
        another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
        07-07-2025, 11:53 AM
      • DynaxSC
        Extreme High Current & Low Voltage Short Killer ??
        by DynaxSC
        Hi Folks
        I'm looking for a extreme high current short killer solution for a reasonable cost.
        I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
        After taking off the socket, the shorts dissappear again.
        The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
        10-15-2024, 10:13 AM
      • duwane
        MacBook Pro A1278 - No charger light, no PPBUS_G3H, SMC_BC_ACOK short when powered
        by duwane
        Hi All.
        I have a very strange issue that I have been trying to fix for a few days now.
        Model: MacBook Pro A1278
        Logic board: 820-3115-B
        Laptop history:
        No visible liquid damage/corrosion, but found evidence of other rework (flux) so any signs of liquid may have been cleaned. The laptop went in for a battery replacement but wasn't working afterwards and was deemed unfixable (as told to me by previous owner). Not sure if this was by Apple, or another repair company. The flux found was found around ISL6259HRTZ, so can assume it was replaced...
        05-15-2022, 05:22 PM
      • ikelectro
        After bios recovery by pen drive HP15s eq0007AU display flashing a light for short time.
        by ikelectro
        Schematic : DAOP5EMB6E0 REV:E​
        I have tried manually flashed the bios, also tried hp bios recovery tools to recover the bios. But no luck. Display is not coming, 3 to 4 times recovery display is coming if I tried to recover by pen drive[win+ B]. But after restarts it goes to dark screen and a light is flashing after a certain time in the display + fan speeds increasing and decreasing. I have tried almost every bios for this motherboard avaiable in the internet.
        Any help or guide to proceed?...
        03-19-2025, 08:17 PM
