Asus GL551
  • trashmonkey
    • Dec 2017
    • 7
    • Serbia
    Asus GL551
    I have a problem with my GL551JM. Long story short: I've installed an SSD via a caddy (instead of the DVD drive). After I noticed it was on a SATA2 connection I swapped the HDD (on SATA3) with the SSD, but it was still booting from the HDD. After some tries to make it boot properly by changing boot priority in the BIOS, I decided to take the HDD (together with the caddy) out of the laptop. But the BIOS still detected a "CD/DVD" drive. So I wanted to see what would happen if I chose that as the boot option, and poof - I bricked the laptop.
    I know the laptop is working, hardware wise it's in good condition, the only problem is the BIOS. I've tried taking out the CMOS battery from the mobo - that did nothing. I've tried taking out the battery and doing the CTRL+HOME combo with a FAT/FAT32 usb (even found one <4GB), the laptop reads the stick but it doesn't boot. The file names were extracted with the Phoenix tool, I've tried AMIBOOT.ROM+.BIN, BOOT.ROM+BIN,kept the original extension etc... Nothing worked. It just reboots after that, the keyboard and LED indicators light up for a few moments and nothing happens (left it on for a while). Sounds to me like I might need to flash the BIOS chip on the laptop, and I've found this youtube video which pointed me to the forums.
    Has anyone tried to flash the chip with the clip? Can anyone give me a valid BIOS dump? My BIOS version was 204 iirc.
    The web is full of complaints of the same problem by various Asus laptop owners, just can't believe they haven't made an official tutorial on how to flash the NVRAM without electrocuting yourself or killing the device.
    Thanks in advance
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: Asus GL551
    it is not always possible to reprogram the bios with the clamps, sometimes it is necessary to desolder the supply pin or (better) unsolder the whole chip.
    When you reprogram the bios with a programmer you lose all information related to your motherboard but you can enter them later.
    Try removing all the ram, the hd and the battery and press the power button, insert a bank of ram and try turning on.
    If you want a bios dump post the number and revision of the motherboard.
    • trashmonkey
      • Dec 2017
      • 7
      • Serbia
      Re: Asus GL551
      I've tried to remove the ram, the HDD, the battery, tried shorting JRST2001 and JRST2002 (not crossing them tho), and again, it's still bricked. Shorting 2001 does make it power on by itself but the end result is the same (or so it seems to me). Shorting 2002 pretty much kills it, but shorting 2001 after that makes it power on again. Am I doing something wrong? Has anyone actually successfully recovered with the CTRL+Home+Power combo?
      • trashmonkey
        • Dec 2017
        • 7
        • Serbia
        Re: Asus GL551
        Update: the mobo is 60NB06R0-MB3020, AAQ20
        • trashmonkey
          • Dec 2017
          • 7
          • Serbia
          Re: Asus GL551
          Bump, anyone with a bios dump?
          • cacla
            • Apr 2015
            • 442
            Re: Asus GL551
            Pls sent me sn for this model and i will find you a correct dump
            • cacla
              • Apr 2015
              • 442
              Re: Asus GL551
              Here is your dump by sn. pls sent msg if is this is ok or not.
              • trashmonkey
                • Dec 2017
                • 7
                • Serbia
                Re: Asus GL551
                Update:
                The file is valid and works fine (even tho it says N series, they're pretty much the same).
                So, for the poor souls that happened to brick their laptops - the best way is to reprogram the BIOS chip by desoldering it, dumping the file onto the chip and soldering it back on. The chip my laptop has is Winbond's W25Q64FVSIQ, be sure if you're replacing this chip that you get _EXACTLY_ the same chip. I tried flashing a brand new chip which was almost the same (W25Q64FVSIG), but according to https://cdn.badcaps-static.com/pdfs/...d69fd34b31.pdf , page 86 , it didn't have "QE=1 in Status Register-2".
                Hope this helps anyone in need, and a huge thanks to cacla!
                • jasko_jacker
                  • Oct 2014
                  • 1137
                  • italy
                  Re: Asus GL551
                  It's explained on page 17 but I think this is an option for quad mode ( page 10 ), what programmer you use ?
                  if you be able to program it there are no differences
                  • trashmonkey
                    • Dec 2017
                    • 7
                    • Serbia
                    Re: Asus GL551
                    Tried doing it with a Raspberry, but I couldn't get a read of the chip, ended up giving it to a local repair shop to dump the file.
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • grimacelord
                      by grimacelord
                      07-10-2025, 02:52 PM
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • lrouw84
                      Asus vivobook s510ua bios changed to x510un
                      by lrouw84
                      Hi there,
                      I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                      I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                      01-28-2023, 01:31 PM
