SIO remove pads on the board
  • String2016
    • Nov 2015
    • 2229
    • philippines
    hi everyone i got a laptop which was the sio chip removed maybe the other technician remove this but the problem is 3pads have remove on the board is there a way i can connect again the chip?please help
  • vinceroger69
    • Mar 2012
    • 6714
    Re: SIO remove pads on the board
    good clear pictures of the area on the board will help us
    • String2016
      • Nov 2015
      • 2229
      • philippines
      ok thanks for the response this is the image attached
      • fester
        • May 2017
        • 158
        • Slovakia
        you can connect it,i see only one missing pad,it is 6th pin from the end(pin nr.123).You must look in schematic,maybe is not conected and under the pin was only free pad. Other pins carefully straighten with some pike tool and solder it back..fine solder tip,good flux and microscope-10minutes of work
        • String2016
          • Nov 2015
          • 2229
          • philippines
          where should i connect the missing 123pin?
          • fester
            • May 2017
            • 158
            • Slovakia
            look in schematic for this board..if you dont have it,post the motherboard number
            • String2016
              • Nov 2015
              • 2229
              • philippines
              board code is x450ep rev 2.0
              • caspian
                • Oct 2015
                • 1589
                • Laptop
                I see some pins are connected together. Do not plug power/battery into the laptop to avoid damaging the SIO.
                • fester
                  • May 2017
                  • 158
                  • Slovakia
                  i dont have schematic for this board but this one pin can be also not connected-not in use..separate the pins and solder it back to the board..leave the one unconected,i dont see any trace going to this pin
                  • dellxps15
                    • Feb 2014
                    • 1588
                    • italy
                    some pins looks like bend (or bent ) . check with good magnifier if they are isolated or touch other pins before give power. if so, better put a new one and use a bit of extra solder 60-37 without extra flux on the missing pad.
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • gusto
                      How do I remove the chip from the board
                      by gusto
                      I am new to hot air soldering. I need to remove one chip from the board. I have a hot air solder and I set the temperature to 350°C. I slowly started heating the chip, but the solder didn't melt. I heated it for about 5 minutes, but the solder still wouldn't melt. I increased the temperature to 450˚C and still nothing. After a while, the board started to change color, but the solder still didn't melt.
                      Fortunately, I'm testing it on old network switches to see how it works.
                      What am I doing wrong?
                      I've seen a lot of videos on youtube and everyone got the solder melted and the...
                      10-08-2024, 10:55 AM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
