Question about MacBook Apple.
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    It's normal that MacBook without battery don't turn on?
    If i put battery laptop turn on, if meanwhile is on i remove battery and use magsafe ac adapter it stay on.
    But i want use MacBook only with ac adapter dont work.
    Thank you for any support.
    N.B. battery charge is ok.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Question about MacBook Apple.
    Works without battery.
    • Pragmatiko
      • Jul 2013
      • 468
      • IT
      Whork without battery with ac only if i remove battery when is turned on
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        every mac that i have worked on, thats not a lot, maybe 10 would work without any battery
        hope that helps
        Im Back... sort of...
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • fisha
          Apple macbook Pro Retina A1398 Battery not charging
          by fisha
          Hallo everyone, my A1398 do not charging the battery and the battery also do not bin recognized. I did all the reset work, SMC reset and all the other reset options but nothing helped. on the SMC at pin 2 (DCIN) there are 20,4V coming in. at pin 16 (BGATE) which goes to the Q7155 Gate there are only 11,43V. at the pin 1,2 and 3 on the Q7155 (Source) there are 12,23V. Cap C7126 is not shorted. As I understand, the gate voltege have to by higher then the source voltege for the gate to clous so the battery can be charging, am I right? can someone help me with this? I guess that manny models are working...
          07-20-2024, 08:39 AM
        • gboone
          820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
          by gboone
          Hi, I was given this laptop by my uncle who said:
          • It would occasionally shutdown if not plugged in
          • battery had been replaced
          • touchbar would "strobe"
          I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
          After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
          BUT
          When powered off, it would at some point have a...
          01-27-2025, 09:12 AM
        • mferna14
          MacBook Air A2681 battery problem after Screen Replacement
          by mferna14
          Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
          12-06-2024, 08:10 PM
        • mkdj
          ASUS X571 no power : battery issue?
          by mkdj
          Mark and model: ASUS X571
          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
          Tests already made:
          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
          - I have removed...
          07-14-2025, 09:16 AM
