Dell 15-AAL15 LA-D071P
  • borbooroski
    • Mar 2014
    • 177
    • Ghana
    Please guys i greet everyone here, i need a help
    there is this Dell 15-AAL15 LA-D071P which is given me hell
    When you plug in the Charger then the charger gose off i try all i could but still i saw this mosfet but when i change the mosfet and plug the charger again it will stay on for just 5seconds then the charger go off again. i dont know whatr to do please help your brother
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: Dell 15-AAL15 LA-D071P
    19v short check 19v line many time this problem is 19v capactor. Remove the mosfet and check all caps 19v.
    THIS MOTHERBOARD NO HAVE SCHEMATIC.
    • borbooroski
      • Mar 2014
      • 177
      • Ghana
      Alright imranromi Thank You for the responds
      • borbooroski
        • Mar 2014
        • 177
        • Ghana
        i can't find anything
        • borbooroski
          • Mar 2014
          • 177
          • Ghana
          please You guys are the best i know you can help me out.......Please
          • borbooroski
            • Mar 2014
            • 177
            • Ghana
              Great Sage é½Šå¤©å¤§č–
              • 30928
              does the dell have a model name?
              • imranromi
                • Jan 2015
                • 1288
                • Pakistan
                Dell insipron 5559 model. 6th generation motherboard.
                • borbooroski
                  • Mar 2014
                  • 177
                  • Ghana
                  • indu
                    • May 2015
                    • 30
                    • srilanka
                    https://www.badcaps.net/forum/showth...light=la-d071p
                    • zhanok
                      • Aug 2013
                      • eua
                      I have the same problem. Did you find a solution?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        No one can help you here in forum(can help you to the right path only). Its you who have to find the faulty component physically. 19v line is shorted so have patience. Check mosfet and capacitors. Likely you have more then one componenet failure.
                        • vhn1998
                          • Jun 2015
                          • 56
                          • Vietnam
                          this is schematic. you check pin 1, pin 2 PU703
                          • Drassh
                            • Apr 2017
                            • 43
                            • Mexico
                            Thanks for heƱping in findind the schem and sharing it here. Very much appreciated
                            • nashdumur
                              • Feb 2016
                              • 7
                              • Mauritius
                              Hello guys, I have somewhat same problem but this one had a short on 5vs rail, so I found the following component short and replaced:
                              1. PU102
                              2. UZ2
                              3. PU603
                              4. PU605
                              5. HDA27
                              Now the led white for 1 second and off, only 5valws/3valws present. Now for this 1 second signal vr_on is 3v on pin 40.
                              Replaced bios chip from a donor board, now fan spins up. After solid white led goes off no display coming.
                              Does anyone has solution for this problem or did I miss something or did something wrong? Any help from you guys is very much appreciated.
                              • Sojke
                                • Apr 2017
                                • 131
                                • Serbia
                                Try clearing management engine.
                                • prlio
                                  • Oct 2017
                                  • 21
                                  • Cairo
                                  • BTubbs200
                                    Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                    by BTubbs200
                                    Dell Latitude 5420 P137G
                                    Board: LA-K491P REV A01
                                    I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                    Board seems to have no shorts, all power rails are fine and show high resistance.
                                    When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                    01-24-2025, 08:15 PM
                                  • Johndill
                                    Dell Inspiron 7567 LA-D993P odd charger issue
                                    by Johndill
                                    Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                    There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                    I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                    Here are the tested scenarios:
                                    1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                    2. With the laptop off, plug in charger (LED says on) & the front charging...
                                    11-16-2022, 10:55 PM
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                  • exerion5000
                                    DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
                                    by exerion5000
                                    Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
                                    below normal, as if it were operating in an extreme energy...
                                    10-15-2023, 02:12 PM
                                  • aaronkatrini
                                    DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                                    by aaronkatrini
                                    I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                                    - Put the card in my testing motherboard and start running Heaven benchmark
                                    - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                                    - Try to start it again and I get a slight move from the PSU fan - a clear short
                                    - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                                    - Put the...
                                    05-18-2025, 04:18 PM
