hi everyone i have this NEO BASIC B2235 laptop at first when i install normal windows 7 shutsdown after 30 minutes to 1 hours so i try lite version of windows 7 boots fine and no shutdown if i leave the laptop without doing anything but if i use installing softwares and drivers automatically shuts off. i already change the processor the same problem anyone can help on this please is this ME REGION problem? it is a core 2 duo 2ghz processor even i change to lower 1.6 the same issue i already add 1 330uf tantalum caps but the same issue.anyone can help me on this please
					neo basic b2235 shutdown if heavy usage
	Tags: None
Re: neo basic b2235 shutdown if heavy usage
anyone can help me on this please laptop shuts down automatically if i install a software or any drivers but when i leave it open with no activity laptop not shut off automatically anyone please give an advise to solve this please -
I have some comments about your situation :
1- You changed the CPU with another one , and i think it's used and may be defected too . In such case , you can always try a Dual core instead of an I core 2 if you have A reliable one . It's compatible .
2- Did you try another Rams ?
3 - You said you added a 330 microF. but maybe one of the other ones is leaky , so better replace all if it is a Token , or replace all the 330 microF on the cpu VCORE rails .
4 - If you did all the above , and the problem remain , then re-install any windows 7 , and install all the drivers , except the VGA's driver .
If the problem disappear or at least become very rare to occur , then you have a problem in the graphics chipset .Comment
thanks for the response ill never tried cpu dual core i only try there cpu with core 2 duo i will try with dual core. the problem with this if i watch video no shuts off but when i install software like microsot office and net framework the installation cannot finished it automatically shuts off. ill try change the other tantalum caps ill tried already lot of rams form 2 gig to 4 gig but still the same issueComment
Sounds like the heatsink. I would also check the CPU fan...hi everyone i have this NEO BASIC B2235 laptop at first when i install normal windows 7 shutsdown after 30 minutes to 1 hours so i try lite version of windows 7 boots fine and no shutdown if i leave the laptop without doing anything but if i use installing softwares and drivers automatically shuts off. i already change the processor the same problem anyone can help on this please is this ME REGION problem? it is a core 2 duo 2ghz processor even i change to lower 1.6 the same issue i already add 1 330uf tantalum caps but the same issue.anyone can help me on this pleaseASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
It could be overheating indeed, check CPU temperature (with SpeedFan for example).
As it appears to be a SiS chipset (I didn't check earlier), there is no ME region so that's not your issue.
Make sure you disconnect the battery and use a proper power brick.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
thanks for the response friends i thin this is overheating because when i use speed fan software cpu temp core 0 and core 1 reach 54c ill try to change this cpu to dual core and see what happensComment
54°C is actually pretty cool if it's under load. If it's idle that's not that cool but it's not a high temperature either.
Start a stress-test and check what temperature the CPU reaches.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
thanks again friends i change the processor to dual core and reinstall new os and now it ok i can install now the softwares withoud automatically shuts off and it been couple hours laptop working without problem thanks againComment
			by howardc64History
- Got TV free. Prior owner claims Vizio logo shows up then nothing. He found U202 EEPROM replacement info (I know NickTV says its never EEPROM haha). Lifted 5 pads removing U202 without proper tools and thought thats end of main board. Gave the TV to me.
- I repaired U202 pads and connections. Soldered on prior owner purchased aftermarket EEPROM (original EEPROM was tossed). TV boots to VIZIO logo, then goes blank, shutsdown after a min or so and power on light blinks a number of times.
- Fixed 2 circa 2015 Vizios before with classical main board... -
			by kacangpoloI have problem with my laptop, with code board X415EA 2.0,
laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
I did :
1. Flash Bios
2. RTC_RST 3.3V
3. LID_SW 3.3V
4. WLAN_WAKE# 3.3V08-26-2025, 04:42 AM -
			by cruiser_hi there,
Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
Gives shutdown cause -128.
Seem to work fine in SMC bypass.
Same shutdown happens with disconnected TP/KB/KBLED/CAM.
Observations:
- SMC_RESET_L - when pulled down - plug goes orange/green and... -
			by kuba2102Medion Erazer beast x25 62307 MSN 30031969 GM5ZGXW AMD version
Hello. The laptop freezes and resets only at low CPU usage, practically at IDLE after a few minutes. There is no problem under a load, and I benchmarked it for over an hour. I noticed that one of the CPU coils was making whining noise at low CPU usage. I previously thought it was a BIOS problem, but updated BIOS and no change. I'm thinking of changing the CPU DrMos'es there are 5 of them all together. I have already swapped the DrMOSes first one with the last one (I desoldered them and soldered in swapping DrMos no.1 with...01-06-2025, 09:14 PM -
			hp fpw50-la-h323p rev 1.0
automatic shutdown after 30 sec of display coming
do not shutdown without ramstick
someone give me idea plz08-20-2024, 03:50 AM - Loading...
