hp fpw50-la-h323p rev 1.0 automatic shutdown after 30 sec, need help
  • RATIM SIDDIQUE
    • May 2024
    • 7
    • bangladesh
    automatic shutdown after 30 sec of display coming
    do not shutdown without ramstick
    someone give me idea plz
  • kacangpolo
    Asus X415EA Auto start when shutdown ( Laptop cannot shutdown with baterai only )
    by kacangpolo
    I have problem with my laptop, with code board X415EA 2.0,
    laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
    I did :
    1. Flash Bios
    2. RTC_RST 3.3V
    3. LID_SW 3.3V
    4. WLAN_WAKE# 3.3V
    08-26-2025, 04:42 AM
  • cruiser_
    A1466 820-00165 intermittent shutdown
    by cruiser_
    hi there,
    Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
    Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
    Gives shutdown cause -128.
    Seem to work fine in SMC bypass.
    Same shutdown happens with disconnected TP/KB/KBLED/CAM.
    Observations:
    - SMC_RESET_L - when pulled down - plug goes orange/green and...
    10-11-2022, 12:06 PM
  • howardc64
    P502UI-B1E shutdown automatically after 75s followed by power light blinking 15x
    by howardc64
    History
    - Got TV free. Prior owner claims Vizio logo shows up then nothing. He found U202 EEPROM replacement info (I know NickTV says its never EEPROM haha). Lifted 5 pads removing U202 without proper tools and thought thats end of main board. Gave the TV to me.
    - I repaired U202 pads and connections. Soldered on prior owner purchased aftermarket EEPROM (original EEPROM was tossed). TV boots to VIZIO logo, then goes blank, shutsdown after a min or so and power on light blinks a number of times.
    - Fixed 2 circa 2015 Vizios before with classical main board...
    11-28-2020, 04:25 PM
  • ronelex
    Acer MS2304 Shutdown when HDD or ODD Present
    by ronelex
    Model: Acer MS2304
    Board Code: 09920-2
    Issue: Unit Powers On with Display Without HDD or ODD attached
    When ODD or HDD is present unit powers on then Shutdown it reaches current of 1A that looks like want to boot but it will shutdown
    Unit wont shutdown when ODD or hdd attach if no ram is attach also
    I have tried flashing bios, the only different it will not shutdown immediately reaching 1A but eventually will shutdown also
    05-15-2021, 01:28 AM
  • mo000
    i need idea about bypass hp omen fans
    by mo000
    hi
    i have hp omen gaming laptop
    the fan not spining and i have 90b error
    on fan connector
    pin 1 =gnd
    pin2(fan signal)=3.3v
    pin3(+12fan)=12v
    pin4(pwm)=0.12v
    pin4 goes straight to kbc
    is that the kbc is faulty
    i try to inject 1.2v on pin4 the fan start spining but full speed
    any idea to bypass pin4...
    10-28-2025, 06:07 PM
