neo basic b2235 shutdown if heavy usage
  • String2016
    • Nov 2015
    • 2235
    • philippines
    hi everyone i have this NEO BASIC B2235 laptop at first when i install normal windows 7 shutsdown after 30 minutes to 1 hours so i try lite version of windows 7 boots fine and no shutdown if i leave the laptop without doing anything but if i use installing softwares and drivers automatically shuts off. i already change the processor the same problem anyone can help on this please is this ME REGION problem? it is a core 2 duo 2ghz processor even i change to lower 1.6 the same issue i already add 1 330uf tantalum caps but the same issue.anyone can help me on this please
  • String2016
    • Nov 2015
    • 2235
    • philippines
    Re: neo basic b2235 shutdown if heavy usage
    anyone can help me on this please laptop shuts down automatically if i install a software or any drivers but when i leave it open with no activity laptop not shut off automatically anyone please give an advise to solve this please
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      I have some comments about your situation :
      1- You changed the CPU with another one , and i think it's used and may be defected too . In such case , you can always try a Dual core instead of an I core 2 if you have A reliable one . It's compatible .
      2- Did you try another Rams ?
      3 - You said you added a 330 microF. but maybe one of the other ones is leaky , so better replace all if it is a Token , or replace all the 330 microF on the cpu VCORE rails .
      4 - If you did all the above , and the problem remain , then re-install any windows 7 , and install all the drivers , except the VGA's driver .
      If the problem disappear or at least become very rare to occur , then you have a problem in the graphics chipset .
      • String2016
        • Nov 2015
        • 2235
        • philippines
        thanks for the response ill never tried cpu dual core i only try there cpu with core 2 duo i will try with dual core. the problem with this if i watch video no shuts off but when i install software like microsot office and net framework the installation cannot finished it automatically shuts off. ill try change the other tantalum caps ill tried already lot of rams form 2 gig to 4 gig but still the same issue
        • jiroy
          • Jun 2016
          • 2416
          • Lebanon
          Well friend , We usually do the reverse , from Dual core to I core 2 to raise the laptop price , lol , but in your case , it's okay for testing purposes .
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Sounds like the heatsink. I would also check the CPU fan...
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • piernov
              • Jan 2016
              • 4435
              • France
              It could be overheating indeed, check CPU temperature (with SpeedFan for example).
              As it appears to be a SiS chipset (I didn't check earlier), there is no ME region so that's not your issue.
              Make sure you disconnect the battery and use a proper power brick.
              • String2016
                • Nov 2015
                • 2235
                • philippines
                thanks for the response friends i thin this is overheating because when i use speed fan software cpu temp core 0 and core 1 reach 54c ill try to change this cpu to dual core and see what happens
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  54°C is actually pretty cool if it's under load. If it's idle that's not that cool but it's not a high temperature either.
                  Start a stress-test and check what temperature the CPU reaches.
                  • String2016
                    • Nov 2015
                    • 2235
                    • philippines
                    thanks again friends i change the processor to dual core and reinstall new os and now it ok i can install now the softwares withoud automatically shuts off and it been couple hours laptop working without problem thanks again
                    • howardc64
                      P502UI-B1E shutdown automatically after 75s followed by power light blinking 15x
                      by howardc64
                      History
                      - Got TV free. Prior owner claims Vizio logo shows up then nothing. He found U202 EEPROM replacement info (I know NickTV says its never EEPROM haha). Lifted 5 pads removing U202 without proper tools and thought thats end of main board. Gave the TV to me.
                      - I repaired U202 pads and connections. Soldered on prior owner purchased aftermarket EEPROM (original EEPROM was tossed). TV boots to VIZIO logo, then goes blank, shutsdown after a min or so and power on light blinks a number of times.
                      - Fixed 2 circa 2015 Vizios before with classical main board...
                      11-28-2020, 04:25 PM
                    • cruiser_
                      A1466 820-00165 intermittent shutdown
                      by cruiser_
                      hi there,
                      Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
                      Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
                      Gives shutdown cause -128.
                      Seem to work fine in SMC bypass.
                      Same shutdown happens with disconnected TP/KB/KBLED/CAM.
                      Observations:
                      - SMC_RESET_L - when pulled down - plug goes orange/green and...
                      10-11-2022, 12:06 PM
                    • kuba2102
                      Medion Erazer beast x25 freezes and resets only at low CPU usage
                      by kuba2102
                      Medion Erazer beast x25 62307 MSN 30031969 GM5ZGXW AMD version
                      Hello. The laptop freezes and resets only at low CPU usage, practically at IDLE after a few minutes. There is no problem under a load, and I benchmarked it for over an hour. I noticed that one of the CPU coils was making whining noise at low CPU usage. I previously thought it was a BIOS problem, but updated BIOS and no change. I'm thinking of changing the CPU DrMos'es there are 5 of them all together. I have already swapped the DrMOSes first one with the last one (I desoldered them and soldered in swapping DrMos no.1 with...
                      01-06-2025, 09:14 PM
                    • RATIM SIDDIQUE
                      hp fpw50-la-h323p rev 1.0 automatic shutdown after 30 sec, need help
                      by RATIM SIDDIQUE
                      automatic shutdown after 30 sec of display coming
                      do not shutdown without ramstick
                      someone give me idea plz
                      08-20-2024, 03:50 AM
                    • MuertoGB
                      Mac EFI Toolkit
                      by MuertoGB
                      Hi all. I'm Muerto, the creator of SMCTool/SMCFT. I thought this would be a good home for discussion regarding an open source pet project I've been working on that aims in easing Mac BIOS/UEFI analysis and editing. It is currently developed for Windows, however is Wine compatible based on my own testing, and feedback from others. Project available on Github, there is also a manual with basic usage instructions.
                      In terms of editing, it can export and replace the Fsys Store, edit the serial number + hwc, clean NVRAM stores, export and replace the ME Region in a limited...
                      09-15-2023, 05:45 PM
